Rear tires bald only on the insides???
Old 09-28-2004, 08:03 AM
mpol99
mpol99's Avatar
Default Rear tires bald only on the insides???
@ ~17k miles, my rear tires are worn out on the inside (only about an 1" or an 1" and a half. The rest of the tire still looks good, but that inside strip on both rear tires are bald.
Is this a problem, anyone else experience this?
Should I take it in for this? I did have my front tires replaced for free due to the tire feathering/allignment issue before.
Old 09-28-2004, 10:11 AM
ThumpAZ
ThumpAZ's Avatar
The rear end of the 350 has a high amount of negative camber from the factory. This will cause a seemingly uneven wear pattern on the rear tires. This wear will be excelerated by agressive driving (burning out, drifting, agressive cornering).
It is to be expected with the design of the system.
To see what I am talking about, stand about 20 feet back from your car and look at the real wheels, they are tilted inward at the top. Now look at almost any other car and notice this apparent lack of tilt.
This is part of the price we pay for a car that handles worth a crap.
Old 10-22-2004, 03:05 PM
bwilliams
bwilliams's Avatar
Default Rear Tires Bald?
mpol99,
I have a slightly different opinion than that express above.
Yes, we have more camber (tires lean in at top) than you may be accustomed to, which will tend to wear the tires more as you move inboard on the tread pattern. Camber does not cause a concentration/isolated wear on only one side of the tire.
I suspect you have a toe out problem. Get NIssan to buy you new tires for rear and an alignment. As additional insurance, have an independent shop check rear alignment (but don't adjust) and go to Nissan armed with proof.
Old 10-23-2004, 11:10 AM
peterhong
peterhong's Avatar
Aftermarket springs/shocks?? If not, we do have the camber mentioned above, but on a stock setting it shouldn't have too much of a problem. Take it to Nissan and show them and I'm sure they will give you some sort of grief about "its totally normal" or "these cars come with high performance soft tires, so what do you expect" or some other nonsense.
Old 10-23-2004, 11:29 AM
HyperSprite
Mad Scientist
HyperSprite's Avatar
Isn't there some sort of tire swapping between rims on either side that is supposed to take place at 10k so the insides are on the outsides?
Chris
Old 11-03-2004, 06:55 AM
Type350Z
Type350Z's Avatar
I went to Nissan with the same problem and they basically told me to f*&# off. Service guy came out and looked at my car and said that they were worn evenly when the insides were completely bald and you could probably get a finger stuck in the outside tread. That was only at 12k miles. Next time it happens im going to a couple different shops and get them to write me up an invoice before I go back to Nissan.
Old 11-03-2004, 07:56 AM
devildogg
devildogg's Avatar
A couple of months ago I changed rims and tires. My RE40's on the rear where worn to the wear bars.(30k no complaints). The outside tread blocks were still good. I was told that it was due to too much air pressure (35 lbs). Tire tech recommended I lower the rear pressure to 32 lbs. We'll see!
Regards
Old 11-03-2004, 08:16 AM
dnguyent
dnguyent's Avatar
You should definitely get your toe checked. Camber may be aggressive on our cars, but it shouldn't cause balding of the inside like you described. My rear toe alignment was slightly off, and is actually wore the outside a bit faster, which I would never have expected with such negative camber.
Old 11-04-2004, 05:02 AM
Asterix
Asterix's Avatar
Yes, check the toe. Also, you should take those corners faster. That'll even out the wear.
Asterix
Old 11-12-2004, 09:18 PM
corsair
corsair's Avatar
Regards
I agreed with this. Sounds like this could be caused by overinflation.
Old 11-14-2004, 08:53 AM
Beaker02
Beaker02's Avatar
Mine went to 35K and were replaced due to the inner edge ware. Have Pilot Sports on now. Hope to go to 70K. We'll see.
Old 11-18-2004, 01:26 PM
msand22
msand22's Avatar
have the same problem with inner edgewear on my rear tires, but I think it is more of a camber problem because I have 20" rims. If you look at my car from the rear you can see the car has serious negative camber like this: /=\ I believe this is caused by the larger diameter rims (correct me if im wrong). I have seen many rear camber adjusters sold on the internet rangeing from $200 to $600 to correct this problem but i wonder if the adjusters will affect the handling of the car?
Old 11-19-2004, 08:13 AM
bosotheclown2002
bosotheclown2002's Avatar
The size of the tire/rim combination will not affect the Camber. Only changing the ride height, lowering the car, will change the Camber. The factory default settings of -1.5 is usually too aggressive for everyday driving and you should have it reset to -1.0 which is the maximun per the Nissan specs.
Some 3rd party shops try to say that the Camber is not adjustable on the 350Z but it certainly is and they do not want to adjust then take it somewhere else to someone who will.
Old 11-22-2004, 01:48 PM
jedi Z(1)
jedi Z(1)'s Avatar
tire/wheel size will affect camber if the overall height of the tire/wheel combo is greater than what it replaced. Think about it
Lt_Ballzacki
08-06-2021 06:19 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
10-04-2015 07:55 PM
Quick Reply: Rear tires bald only on the insides???
