what do you think about this?
Old 02-10-2004, 10:24 PM
all_bark
all_bark's Avatar
Default what do you think about this?
my dyno's plotted two different ways.
one is the original, with no sae correction
numbers are this:
baseline -248.9
+ cats -253.4 (+4.5 rwhp)
+ plenum-266.88 (+13.4)
total gained =17.9
Old 02-10-2004, 10:30 PM
all_bark
all_bark's Avatar
now the sae corrected numbers smoothed to 3
baseline sae 239.1
+ cats 248.1 (+9 rwhp) WHY?
+ plenum 256.7(+8.6)
total gained = 17.6
just about the same.
so what I want to know is this...
why did the sae corrected number RAISE the cat and LOWER the plenum but come out about the SAME?
Old 02-10-2004, 10:31 PM
fairladyZ in Japan
fairladyZ in Japan's Avatar
all_bark... niiiiiiiiiiiiiiiiiiice !
Damn.. I hope NISMO offers something like this plenum in the future.....
Old 02-10-2004, 10:36 PM
Z8M
Z8M's Avatar
Awesome!! Clearly the graph shows a wide gain throughout the rpm range. Congrats, I bet you're just grinning from ear to ear driving your Z. Say no more, I'm convinced..
Phatmitzu
Phatmitzu's Avatar
sorry, but whats a sae?
Old 02-11-2004, 12:31 AM
mchapman
mchapman's Avatar
FYI You didnt put plenum in the name of this thread.
Old 02-11-2004, 04:01 AM
VandyZ
VandyZ's Avatar
Because it factors in environmental variables. Even dynos as close as 20 minutes can be skewed from the environment.
Unfortunately even SAE correction can be skewed, as some shops place the weather station in odd locations (but that is neither here nor there).
SAE corrected values should be used when comparing dyno runs from different groups, especially different days.
For example, on my base lines sae added power and on my plenum and header runs it took power away. Thus if I were to compare my baseline with my plenum runs as well as my header runs WITHOUT SAE correction I get much better numbers. I have always posted sae numbers, infact Doug and I are the only ones that I know for a fact used SAE on the top 10 N/A list. You should be up there now too. Now the question is which ones are you going to post? If you want to follow the crowd and post non corrected numbers then let me know cause I want to do the same. My 260 number jumps to 269 when I take SAE correction off.
Good numbers by the way!
Old 02-11-2004, 05:36 AM
LiqTenExp
LiqTenExp's Avatar
Default Re: what do you think about this?
He's using this
- 1st Ever Kinetix Plenum
take a look at the bottom of his first post.
Do you have any of the A/F graphs from the runs?
Old 02-11-2004, 05:46 AM
FLY BY Z
FLY BY Z's Avatar
Default Re: Re: what do you think about this?
Originally posted by LiqTenExp
He's using this
guess you have been absent this week.
Old 02-11-2004, 05:53 AM
350zdanny
350zdanny's Avatar
I know my Crawford charts didn't really change when I plotted them uncorrected. The baseline power went up and so did the Crawford power, but I didn't test two products, only one. And if I remember, it was about 32 degrees out with the same humidity and barometric pressure.
Did any of that data change for you?
Old 02-11-2004, 06:06 AM
350zdanny
350zdanny's Avatar
Here is an uncorrected graph. You'll notice that the baseline jumped 8 whp and the Crawford jumped a little less than 6.
Also the variables in my runs are as follows:
Baseline: abslolute pressure - 30.4, vapor - 0.0, air temp 58.6, humidity - 10%, altitude - 0ft
Crawford: abslolute pressure - 30.1, vapor - 0.1, air temp 57.0, humidity - 14%, altitude - 0ft
PS - all bark, what haven't you answered my PM's/questions? I'd really like to get a look at those dynojet files. The post cat one and the final one. I wouldn't really need the baseline. Thanks.
Old 02-11-2004, 03:52 PM
D'oh
D'oh's Avatar
As Vandy mentioned, the SAE correction factor attemps to adjust the HP to what it would read if tested under standard temperature, pressure, and humidity (I don't know exactly what those standard values are, but they are probably online somewhere).
Because these variable will change throughout the day, you should ALWAYS use the SAE correction factor to compare results, otherwise it could simply be the change in weather that is changing the dyno numbers.
Since you were putting down more power "uncorrected", that means that you were getting more air than you would have received under "standard" conditions. Therefore, after applying the correction factor, some of the power was subtracted in an attempt to account for that.
If you had dyno'd on the top of a mountain in the middle of summer during a heat wave, the corrected number would probably be higher than the uncorrected number, but that would depend on what exactly the standard conditions are.
In any case, it is best to use the corrected numbers so that those variables are factored out as much as possible (of course, the correction is only as accurate as those variables, so if the temp sensor on the dyno is fubar'd, then your correction factor will be as well).
-D'oh!
Old 02-11-2004, 04:17 PM
350zdanny
350zdanny's Avatar
My tuner was telling me that depending on your location, some correction factors are better than others. I wonder if there is any truth to that. I'm sure there is or they wouldn't have them.
SAE is just the "standard" on the internet though. If you're posting, people want it in SAE.
Dan
Old 02-11-2004, 06:47 PM
kvjacobz
kvjacobz's Avatar
I'm confuzed. Why is his baseline so low? Didn't he run the baseline with i/e and pullies? I thought 239 hp was average for a stock z????
Old 02-11-2004, 06:55 PM
phile
phile's Avatar
Dan
I do not belive for one second "a smoothing constant of 3 is the best" like some have said here. I have taken about 4 statistics courses, and different methods of smoothing are appropriate for different conditions. So your tuner was correct. A smoothing constant of 3 may overcorrect the results. What if I'm at sea level, with standard temperature, pressure, and humidity? Assuming I am, why would I use a smoothing constant of 3? I would be very interested in knowing what statistical process is used to smooth these values. Having taken a time series class, possibly I could offer some input.
Old 02-11-2004, 07:37 PM
zimbo
zimbo's Avatar
phile... The smoothing constant is something totally different than SAE correction. Smoothing constant means how much jitter do you remove from the dyno plot. A dyno measurement is not actually a contiguous line (as you well know due to your stats expertise) but rather a set of points. If smoothing is not done, those points look very jittery but smoothing can affect the HP number by a point or two.
SAE is a formulaic compensation for differences in altitude, humidity, temperature, etc (I don't pretend to know the exact formula). It tries to nullify the impact those factors have on the reported HP number. In a high heat, high humidity, high altitude situation your dyno would be artificially low because your car is competing with nature more than "normal" to push the car.
As a piece of anecdotal evidence, one of my most recent dyno runs was a whopping 15 HP higher uncorrected than the SAE number was!
--Steve
Old 02-11-2004, 07:48 PM
FLY BY Z
FLY BY Z's Avatar
SAE is normally recalculating your actual dyno results to sea level conditions for altitude (0), temperature to about 77 degrees, barometric pressure to 29.2 in/hg, and humidity to 0%. In the majority of cases, SAE correction will yeild higher numbers unless one of the adjusted variables creates a greater difference than the altitude at which the test is run. For instance, if you are at 800 ft but the humidity is 5% and temperature is 45 deg and barometric pressure is higher than 29, you will probably see a loss from correction even though you are at some altitude. Normally, the correction values will be more optimal for more power and will show higher numbers. What matters is that there is a standard that everyone uses for accurate comparisons.
Old 02-11-2004, 07:51 PM
FLY BY Z
FLY BY Z's Avatar
Here is a good link:
http://wahiduddin.net/calc/cf.htm
Old 02-11-2004, 08:14 PM
rodH
rodH's Avatar
GUYS, I think he is asking something TOTALLY different.
Notice, WHY is the increase in HP different in perportion (the 1st the cats HP is low/plenum high, while the next dyno shows a pretty even balance between the 2 mods) when comparing the SAE and non-corrected dynos, that is weird
ANYONE??
Old 02-11-2004, 08:23 PM
FLY BY Z
FLY BY Z's Avatar
Probably because they are subject to different correction factors since they were dynoed at very different times.
