18" 275's rubbing, fenders rolled on stock suspension - advice needed
Old 05-29-2013, 06:07 AM
Pholicious
Pholicious's Avatar
Default 18" 275's rubbing, fenders rolled on stock suspension - advice needed
How much camber are you guys with 275 40 18 rears running? My rear fenders are rolled and just had an alignment we dialed in a bit more -camber but it still rubs a bit on driver side so I'm going back. I'm on stock suspension
Old 05-29-2013, 07:21 AM
07maximan
07maximan's Avatar
That's weird,what size wheel are you using?
Old 05-29-2013, 07:23 AM
Pholicious
Pholicious's Avatar
18 x 9.5 with 12 offset pretty conservative compared to what most go to...
Old 05-29-2013, 07:46 AM
Bmurray350z
Bmurray350z's Avatar
I was lowered on Tanabe GF210 springs w/ the rear spring mount mod done, 18x10.5 +10 with a 275/40/18, SPC rear camber arms and toe bolts. rear fenders rolled.. -1.2 rear camber
no rubbing
Old 05-29-2013, 07:51 AM
rcdash
rcdash's Avatar
It's more about wheel offset than camber. You can run a much bigger rear tire with the right wheel. I run a 305/30/R19 with a +22 offset I believe, rolled fenders, lowered at least an inch and virtually no camber and it doesn't touch. If you go +27 to +30, I think you can fit a 315.
EDIT: Just saw you are a +12 offset. That's the issue right there...
Old 05-29-2013, 08:31 AM
wird06
wird06's Avatar
Hes right its a wheel offset issue, I'm running 275/40/18 on stock suspension and +25 offset, lots of room.
Old 05-29-2013, 10:58 AM
Chebosto
Chebosto's Avatar
+12 is considered conservative now?
since when?
Old 05-29-2013, 11:54 AM
Phenom
Toasty
Phenom's Avatar
Received 1,382 Likes on 990 Posts
That setup shouldn't rub unless you have a really weak fender roll. I ran 285 tires on a +15 and mine didn't rub at stock height and alignment specs
Old 05-29-2013, 11:56 AM
Phenom
Toasty
Phenom's Avatar
since when?
10.5 +12...pretty aggressive. 9.5 +12...meh
Old 05-29-2013, 12:07 PM
07maximan
07maximan's Avatar
Im running an 11" wheel with a 285 lowered with S Tech's...no rubbing here.
Old 05-29-2013, 12:32 PM
275/40 or 285/35 on the back of mine with 10.5 +10 , fenders rolled and no rub running 2.1 rear camber
Old 05-29-2013, 12:38 PM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Are your fenders rolled flat?
Old 05-29-2013, 12:51 PM
deftoneZ
deftoneZ's Avatar
He's running a taller (40 series) tire and a low offset. Its a combination of both. If he changed one or the other I'd wadger he would be okay.
Old 05-29-2013, 12:53 PM
AdvanZ33
AdvanZ33's Avatar
275/40/18 is the same height as a stock 245/45.
Old 05-29-2013, 03:20 PM
Pholicious
Pholicious's Avatar
275 40 18 is same as stock I was told 12 offset would be fine and its deffinately not aggressive for a 9.5 width wheel many on here run lower offset and wider wheel.
If by rolled flat you mean flat against the inside of the quarter panel then no.
Old 05-29-2013, 04:03 PM
Z-Crazy
Z-Crazy's Avatar
OP, these sizes should not cause rubbing in most cases,
Can you inspect the inner edges of your fender, check if the inner edge has rolled back out.
Another thing to check is your suspension, check if shocks are leaking. This may be a less likely cause but doesn't hurt to check.
Old 05-29-2013, 04:30 PM
ronn1
ronn1's Avatar
That's gonna be a close call with +12, but it should have cleared with STOCK suspension. There are guys running stock wheels (8.5 R) and suspension with 30mm spacers (net +3 offset) with no problems at all. So you should have cleared fenders with 9.5s and +12 which is slightly LESS outboard than the spacer/stock wheel set up.
Old 05-29-2013, 07:14 PM
Actually 9.5 +15 with a 275/40 without a roll will rub on stock suspension.
Old 05-29-2013, 07:34 PM
Bmurray350z
^ Terrasmak, how come my 10.5 +15 with 275/40/18 and lowered on Tanabe Springs didn't rub?
Old 05-29-2013, 07:43 PM
No idea, maybe you had an *** ton of camber. Not all tires are the same width, no idea. My car started to rub at 10.5 +25 with 275/40-18 Nitto Invo
Quick Reply: 18" 275's rubbing, fenders rolled on stock suspension - advice needed
