Undershroud snapped off my v2.
Old 05-28-2013, 10:18 PM
wubongG
wubongG's Avatar
Default Undershroud snapped off my v2.
During the day a bolt snappd off the passenger side of my undershroud that was attached to my V2 bumper. There were only 2 bolts holding the undershroud because the left side(driver side) didnt line up with the bolts.
However I parked my car at friends house and then at night when I was almost home the middle bolt (last bolt that was holding the shoud) snapped off and then it caused my undershroud to fold which I had to flip it back by crawling under the car. Now I dont have any bolts for the undershoud to bolt to the V2
So I was wonder if I could just tape the middle part of the shroud with 3M double sided tape. However the driver side plastic part ripped off and there are no more holes to be bolted on too. Is it okay with just the middle part tapped on? and will it affect anything if the driver side is ripped off a little.
Old 05-28-2013, 10:22 PM
Post pics
Old 05-28-2013, 10:25 PM
wubongG
wubongG's Avatar
Good idea, going to take pics now.
Old 05-28-2013, 10:31 PM
KingBaby
Hardest Setting
KingBaby's Avatar
If its the OEM plastic then the holes are torn and can't be fix...
Zspeed makes a replacement which will stand the test of time...
Old 05-28-2013, 10:35 PM
wubongG
wubongG's Avatar
Here are the pics. No bolts attached and the pic where my hand is the driver side. :/ the middle and right side still touch the bottom of the V2 so I was thinking of 3M taping it.. bad idea?
Attached Thumbnails Undershroud snapped off my v2.-photo-1-1-.jpg   Undershroud snapped off my v2.-photo-2-1-.jpg   Undershroud snapped off my v2.-photo-3-1-.jpg   Undershroud snapped off my v2.-photo-4.jpg
Old 05-28-2013, 10:38 PM
wubongG
wubongG's Avatar
Yea I was looking into that.. but you think 3M tape would last a little while? The driver side is just riped off...
Old 05-28-2013, 10:47 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Sure it will depending how heavy duty the tape it is....
Temporary fix would be to use tape (duck tape or stronger) the top and bottom of the tear. Then poke a hole where the bolt would go. Along with a washer the bolt should/will hold the undershroud back in place.
Old 05-28-2013, 10:56 PM
wubongG
wubongG's Avatar
Oh like tape the tear back together so there's no gap? In the picture where my hand is, the plastic just ripped off. I can't tape it back.. There going to be a gap unless I duck tape the plastic to the bumper itself. Is it fine if there's that gap there though?
Old 05-28-2013, 11:04 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Yea man, if you don't want to get creative you might just wanna leave it off. The undershroud just keep the engine bay free from the elements. It's not needed to get the car around...
Old 05-28-2013, 11:17 PM
wubongG
wubongG's Avatar
It's all good, yea I'm gan tape it in the morning and then ima get some bolts n bolt it on. But thanks man
Old 05-29-2013, 02:52 AM
Depravity
Depravity's Avatar
Like KingBaby said, ZSpeed makes an aluminum undershroud that would be a perfect replacement for you. I bought it with the stainless steel hardware, and that thing isn't going anywhere. If I were you, i'd throw away the plastic one and just leave it off until you can get a proper replacement.
Old 05-29-2013, 07:12 AM
ChevChelios
ChevChelios's Avatar
+1 ^ ...and the zspeed has a door for oil changes.
Old 05-29-2013, 07:36 AM
Marrocco350z
Marrocco350z's Avatar
My Zspeed aluminum piece bolted up perfectly to my V2 replica from VIS and really made the front end solid! Oil changes are amazing, 1 bolt and you have access to everything you need. Highlyyyy recommend buying one!
Old 05-29-2013, 08:03 AM
Highway Riding
Highway Riding's Avatar
Happened to me as well I also shredded the inside lining at very high speeds thought a helicopter was around till i realized it was me on the Highway! This was on a 245/35/19 no drop!
Old 05-29-2013, 10:53 AM
Collin Lacy
Collin Lacy's Avatar
Get an aluminum one! Favorite mod I've done to my car.
Old 05-29-2013, 11:55 AM
fzero
fzero's Avatar
yup got the zspeed and it makes changing oil a breeze
Old 05-29-2013, 07:18 PM
samsniss350z
samsniss350z's Avatar
Why not get an aluminium strip and drill holes to suit use self tappers or nuts and bolts joining the thing together. Be a lot stronger than 3M tape. Plus it will hold it together at speed.
Old 05-29-2013, 07:20 PM
Marrocco350z
This would work for now
Old 05-29-2013, 09:03 PM
wubongG
wubongG's Avatar
Hey guys thanks for the recommendations. Most likely I am going to upgrade and get the Zspeed shroud. But for now I attached bolts and nuts onto the undershroud. The passenger side and the middle still bolted up together and it hangs on just fine. Even though the driver side has the tear I was still able to bolt it onto the V2 bumper since there was another hole further back on the shroud that didnt get ripped off. Luckily the plastic undershroud has a lot of holes..
Old 05-30-2013, 09:55 AM
Jbakes727
Jbakes727's Avatar
Where did you guys order your VIS v2 front bumper? From their website? I can't seem to find VIS on the forums.
Quick Reply: Undershroud snapped off my v2.
