New setup in the works
Old 05-28-2013, 03:06 PM
meatbag
meatbag's Avatar
Default New setup in the works
Starting on the hotside stuff this week. Will post pics as things progress.
Old 05-28-2013, 05:21 PM
samsniss350z
samsniss350z's Avatar
WOW! Looking forward to seeing how this progress's, its looking like an absoluye beast already. Good luck with the build'
Old 05-28-2013, 05:42 PM
binder
binder's Avatar
Did you not have those turbos in that location on the last build or was that some other car I saw? I get the builds mixed up on here. I know you used the 20g turbos but wasn't sure if it was the full kit or custom mount.
Old 05-28-2013, 06:03 PM
meatbag
meatbag's Avatar
I had the 20gs with the stock greddy manifolds hogged out.
I was hopeing to get these new turbos next to the block but they just wouldnt fit unless I ditched power steering and flipped the alternator around and put in front of the motor. Even with doing the motor plate it wasnt enough room.
Old 05-28-2013, 06:05 PM
str8dum1
str8dum1's Avatar
VTR's car has em like that.
aesthetically, that location is awesome and really cuts down on the cold side piping. just need to be able to fab forward facing manifolds. Based on VTRs pics, actually looked very simple.
performance wise, prolly no different than SP/SFR header placement. And i'll keep telling myself that
Old 05-28-2013, 06:12 PM
herrschaft
herrschaft's Avatar
Nice. I wonder if the heat would have any affects on the lights
Old 05-28-2013, 06:27 PM
binder
binder's Avatar
Nobody cares about headlights in the FI section
Old 05-28-2013, 07:54 PM
Boosted Performance
Vendor - Former Vendor
Boosted Performance's Avatar
Since you have to make custom manifolds, will the down pipes rund under them (new manifolds)? If the manifolds are built more "upwards" there may be enough room to run some 3" down pipes on each side. On the passenger side you would need an oil filter relocation kit, but that is no big deal.
Or, you are just having short pipes and no exhaust.
Old 05-28-2013, 08:25 PM
jerryd87
jerryd87's Avatar
http://vibrantperformance.com/catalo...roducts_id=271
plenty of room for mufflers could even have them cross over so driver turbo exits passenger side and vice versa just an idea lol
Old 05-28-2013, 09:19 PM
herrschaft
herrschaft's Avatar
So only trailer queens in here, got it.
Old 05-28-2013, 10:26 PM
jerryd87
jerryd87's Avatar
nope more like people who will sacrifice comforts for power
Old 05-29-2013, 05:26 AM
meatbag
meatbag's Avatar
This is pretty much what im doing except the downpipes are going to run on top of the manifolds. With no motor mounts in the way we have plenty of room for both. Manifolds will go low and to the turbo, downpipe will go over frame rail and motor plate across the top of the manifold and out the back. Or we might just put it out the hood.
Old 05-29-2013, 06:38 AM
Boosted Performance
Awesome!
That also makes more sense...to run the manifolds low and the DP's over the top. Hope to see a lot of pictures on this build.
Old 05-29-2013, 06:51 AM
meatbag
meatbag's Avatar
Awesome!
Weve got a bunch of fab to do to get everything in the car along with mini tubing the rear.
Will have some pictures of the turbo manifolds today after we get them tacked up.
Old 05-29-2013, 10:41 AM
bmyles
bmyles's Avatar
I tried looking in a couple of your other threads and didn't see this mythical motor plate you speak of. Any pics? Super stoked to see your progress.
Old 05-29-2013, 01:59 PM
meatbag
meatbag's Avatar
Here is a picture from when we were still working on it. I can take some more once the manifolds are complete and the front end comes back off.
Old 05-29-2013, 02:16 PM
b18ccivics
b18ccivics's Avatar
I really dont know if I am a fan of the motor plate. the mounting points on the engine are to close together to handle twisting of the engine. Not unless there is something I am not seeing to spread the load out. I would machine 3/8 off of the bellhousing put in a motor plate.
Old 05-29-2013, 02:23 PM
meatbag
meatbag's Avatar
Like i said that pic is when we first started mocking up the motor plate. It has two more mouting points kind of above the alternator and PS pump that going through the plate and into the block.
The car has a mid plate too if that it what you mean.
Old 05-29-2013, 05:39 PM
graffkid732
graffkid732's Avatar
Awesome man. Car was a beast before, can't wait to see to see the results and finished product.
Old 05-30-2013, 10:14 AM
bbs350z
bbs350z's Avatar
oh man im in for this! good stuff!!
Quick Reply: New setup in the works
