Pioneer AVH-X5500BHS Install
Old 04-20-2013, 06:41 AM
canmark
canmark's Avatar
Default Pioneer AVH-X5500BHS Install
I am in the process of installing a Pioneer AVH-X5500BHS head unit. So far pretty straight forward. I am keeping factory Nav and will add a separate speaker and mute circuit for it. Also front and rear cameras.
When I removed the factory Bose I noticed that it had 4 connectors. I know 2 are power and speakers, 1 is for Nav, but I cannot find any info on the 4th connector. I have read it could be for CD changer which I don't have.
I have searched but can't find any info. Any one know what it's for ?
Old 04-20-2013, 06:43 AM
canmark
canmark's Avatar
Test fit
Old 04-21-2013, 05:05 PM
canmark
canmark's Avatar
Here is my harness with ROEM-NIS2, Microbypass and Nav muting circuit using transistor and relay.
Old 04-21-2013, 05:08 PM
canmark
canmark's Avatar
All wired up except for rear camera
Old 04-21-2013, 05:10 PM
quiksilver38
quiksilver38's Avatar
Old 04-21-2013, 05:16 PM
canmark
canmark's Avatar
Funny, I'm using my IPad to post. For some reason it rotates the pics. They look ok in my camera roll.
Old 04-21-2013, 06:17 PM
secwind
secwind's Avatar
Looking good. I was debating between the x5500 and x8500. Ended up getting the x8500 instead. Can't wait to get it.
Old 04-26-2013, 09:45 PM
canmark
canmark's Avatar
Everything is installed and working properly but there is a problem with the Nav speaker.
I built the transistor/relay circuit with it's own speaker to mute the audio when the Nav voice comes on. It work properly but I noticed that the speaker is very warm to the touch. It's connected to L/B on + side and W/B on - side.
The Nav is turned off so no voice directions are active but speaker is still very warm.
Any help on why it's doing this would be greatly appreciated.
Old 04-28-2013, 11:47 AM
canmark
canmark's Avatar
Pics of finished install.
Still don't know if it's normal to have constant 5 volts between L/B and W/B on the nav connector
I have a good 1/2 inch between screen and shifter when in park.
Attached Thumbnails Pioneer AVH-X5500BHS Install-img_0743.jpg   Pioneer AVH-X5500BHS Install-r-camera.jpg   Pioneer AVH-X5500BHS Install-img_0744.jpg
Old 05-29-2013, 04:46 PM
EdMandevil
EdMandevil's Avatar
I have the same head unit and it will not turn on . Any tips? I'm pretty sure I have everything connected
Old 05-29-2013, 04:55 PM
EdMandevil
EdMandevil's Avatar
Can't get my **** too work!
Old 05-29-2013, 05:05 PM
350zchad
350zchad's Avatar
plug antenna in???
OP looks good!
Old 05-30-2013, 07:15 PM
EdMandevil
EdMandevil's Avatar
Originally Posted by 350zchad
plug antenna in???
OP looks good!
Got it thanks!
Old 06-12-2013, 12:47 PM
Airkilo
Airkilo's Avatar
Did you have any trouble with getting the screen to tilt and open? I just finished installing mine and it does not want to open. Seems like it is getting caught on the bezzle.
Old 06-20-2013, 07:10 PM
canmark
canmark's Avatar
It worked fine for me. I tested it before installing it. Maybe it is twisting a bit when you tightened it causing it to bind.
Old 08-07-2013, 01:35 PM
radiivan
radiivan's Avatar
Hey man, I installed a similar radio to my 04 z but it didnt come with a rear view camera; Did you install yours ? Which one did you get ? work good ? Hows the quality of it during the day/night? How'd you hide it on your hatch? Sorry I'm just trying to figure out how I'm gonna do it.
Old 08-17-2013, 11:31 PM
thebeagster2
thebeagster2's Avatar
Default Steering wheel controls?
Did you end up getting it to work with the steering wheel controls? (if you have a Z with steering wheel controls...)
Old 08-22-2013, 07:22 AM
SuZZZ
SuZZZ's Avatar
Default Avh-x5500bhs
Sorry for the PM questions canmark.
Just wondering if anyone else has installed the Pioneer AVH-X5500BHS and which install kit (DIN bezel) they used?
I like the one canmark used and I'm guessing by the pics that it's a Scosche brand? The metra bezel looks like the corners have a half-inch radius with a funky recessed edge.
Also, did anyone use the parking brake micro-bypass switch?
Thanks! -Suzi
Old 08-23-2013, 03:14 PM
canmark
canmark's Avatar
I have the bypass on mine and it works
Old 08-23-2013, 03:15 PM
canmark
canmark's Avatar
I don't have steering wheel controls. All works fine though
Quick Reply: Pioneer AVH-X5500BHS Install
