Car died, barely started, shaking/rough idle. (Video)
Old 10-30-2011, 11:03 AM
Bmurray350z
Bmurray350z's Avatar
Default Car died, barely started, shaking/rough idle. (Video)
So today I was at autozone getting a CEL scanned and got the code P1283. I then proceeded to go eat ad got into the parking lot, midway through a turn, the car dies. I try to start it and it wouldn't start until the 2nd or 3rd try. I then pulled into a parking spot and popped the hood, and the car was just shaking awfully. It sounded like a cammed Camaro. Lol, I know.. Anyways what in the world is this? Battery, maf, etc??? I recently cleaned my MAF and everything has been fine since (a week ago or so).
http://www.youtube.com/watch?v=RQCup6nmXTk
http://www.youtube.com/watch?v=FglTCrwFxbI
Car is a 2004 5AT with 69,000 miles.
It has intake, headers, md 5/16 spacer, and test pipes. exhaust came off last night due to selling it soon..
Old 10-30-2011, 11:55 AM
cgkp0925
cgkp0925's Avatar
I had this happen once a long time ago with another car. I too was coasting through a parking lot and went to press the accelerator and the car wouldn't do anything. Then it died. I was able to start it up one more time but that was it. Come to find out it was the crankshaft sensor. Not sure if this is your problem but it could be a place to start looking.
This Z seems to be nothing but trouble for you lately.
Old 10-30-2011, 12:34 PM
Bmurray350z
It is nothing but trouble honestly. I'll look into that crankshaft sensor for a possible solution. Thanks.
Old 10-30-2011, 12:38 PM
konrad
konrad's Avatar
if its shaking than it sounds like a miss fire , check your plugs and coil packs
Old 10-31-2011, 07:05 PM
03DGCOUPE
03DGCOUPE's Avatar
+1 on camshaft sensor. Mine went out and they are known part to go bad on these. Sometimes it would turn off on me other times it would be fine. Easy fix though one ten mm bolt and it pulls out of the back of the head.
Old 10-31-2011, 07:19 PM
Bmurray350z
I'd hate to buy something, and it not be the solution. I'll most likely see what the dealership thinks it is and go from there.
Old 11-13-2011, 03:10 AM
-Trav-
-Trav-'s Avatar
Where they able to find it? Im starting to have similar problems..
Old 11-13-2011, 06:10 PM
Bmurray350z
I took mine to CIN in Charlotte to have it looked at and they checked everything and couldn't get the problem to reproduce. They did say I had a misfire in the 6th cylinder, but it wasnt to the point to where it should cause any damage. They cleared the ECU and since, it has been fine.
Old 11-15-2011, 12:11 PM
cvc35
cvc35's Avatar
From what your saying its probably the cam sensor in bank 1 (Passenger side). They're known to go out. It happened to me a few months ago. I was driving home from work and all of a sudden the car died. Afterwards it would be really hard to start the car and even died on me again a second time after it finally started up. Scanned the code because my cel came on when i got home and that's when I found that it was the cam sensor. I went to the nissan dealership and they replaced it and even gave me a 1yr warranty on the sensor so if it goes out again within a year ill just hit up the dealership again.
Oh and what ever you do Do not try to skimp and get an autozone one. I did this and found out the hard way that it didn't even fit when i took it to the dealership. The OEM one looks straight where as the autozone one goes at an angle. Just go with an oem sensor, it may be more expensive but well worth it.
Old 11-15-2011, 12:21 PM
chrs870621345
chrs870621345's Avatar
Autozone gave you the wrong side than, the driver side is angled while the passenger side was straight. But It is 100% cam sensor.
Old 11-15-2011, 12:40 PM
cvc35
cvc35's Avatar
those dirty sons of *******! oh well at least i got my money back when i returned it and went with the oem one in the end.
JjL
East Canada
06-12-2019 03:04 AM
pslamp32
02-08-2017 09:07 AM
OdesiTT
09-30-2015 10:47 AM
cashmoney03
09-27-2015 05:24 PM
Darkspy
09-07-2015 09:09 PM
Quick Reply: Car died, barely started, shaking/rough idle. (Video)
