How do you remove the door panel?
Old 08-22-2011, 08:38 PM
Obey_Z
Obey_Z's Avatar
Default How do you remove the door panel?
2005 350z. The driver side door panel was easy to remove! I'm having trouble with the passenger door panel being removed! I took off 3 screws, is there a 4th? If so where.. I don't wana break anything else!
Thanks.
Obey_Z is offline
Old 08-22-2011, 08:54 PM
Bmurray350z
Bmurray350z's Avatar
lol
Bmurray350z is offline
Old 08-22-2011, 09:28 PM
MaelstrØm
MaelstrØm's Avatar
Er, it helps if you tell us which ones you removed. Behind the lock, two inside the door handle, and if I remember, one inside the handrest when you remove that?
MaelstrØm is offline
Old 08-22-2011, 09:41 PM
amossa
amossa's Avatar
it's in the first few posts in this thread: https://my350z.com/forum/maintenance...dow-motor.html
amossa is offline
Old 08-23-2011, 09:03 AM
techtalk
techtalk's Avatar
Seriously. Which one was it, OP? If it helps you out in any capacity, refer to the screw's part code in this 350z door panel diagram.
Was it the hand rest screw? That seems to be the most problematic screw (that's what she said ) for most people..
techtalk is offline
Old 08-23-2011, 11:42 AM
bmccann101
bmccann101's Avatar
you know its bad if i load a photobucket tab as im waiting for my350z to even open the thread.. on title alone, i pulled the trigger.
bmccann101 is offline
Old 08-23-2011, 06:05 PM
Obey_Z
Obey_Z's Avatar
Thanks guys! This really helped! I'm new to this, and yeah. Thanks again!
Obey_Z is offline
3vilbunny
07-18-2017 05:10 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
Depravity
10-01-2015 04:49 PM
Quick Reply: How do you remove the door panel?
