Drag NHRA, IDRC, IHRA, NDRA
How does 60ft time effect your trap speed??
Old 06-18-2011, 07:42 AM
djtimodj
djtimodj's Avatar
Default How does 60ft time effect your trap speed??
Just a quick question guys, Last time I was at the strip my best 60ft was 2.37 sec (crap I know!). My best trap was 116.88mph, If i could get my 60ft down to 2.0/2.1 do you think this would effect my trap speed much??
Thanks.
Old 06-19-2011, 10:37 AM
davidv
davidv's Avatar
I would like to see 2.0 seconds on street tires. Do not know what this will do to trap speed. but but but assume this will decrease ET by 0.37 seconds.
Old 06-19-2011, 11:59 AM
Frosty87
Frosty87's Avatar
I'd imagine that you may gain a MPH or so with a lower 60ft as you probably will have traction sooner
Old 06-26-2011, 10:49 AM
kleefton
kleefton's Avatar
I don't think there is a direct correlation with trap speed and 60' times. Some guys say when you spin off the line you get a higher mph and some guys would argue that a lower 60' time should land a higher mph. My guess is that your MPH will remain the same, provided you are consistent at shifting.
What will definitely improve is your ET. Something like for every .10 in your 60' time expect .15 off your ET.
Old 06-26-2011, 09:11 PM
eltness350
The Untouchable
eltness350's Avatar
for every tenth in the 60ft u gain 2tenths in the 1/4 mile granted u shift the same on every run, traction in other gears are the same etc..... y r u worried about trap speed? should be on the time elapsed....
Old 06-27-2011, 06:33 AM
Alberto
Cranky FI Owner
Alberto's Avatar
Some people feel that with a worse 60ft (spinning) that you can trap higher than if you hooked.
Maybe when talking about 150whp Civics where some spin will actually help them from bogging, that's the case, but in my experience with the Z, especially on slicks and with FI, the better the 60ft, the better my trap.
If you can hook up, then you are making more use of the track and putting down the power sooner. This will help you trap higher.
With my TN setup, when I 60ft'd at 1.96 I would trap 114mph. When I hit low 1.8's I would trap 115-116mph, same day, back to back runs/conditions.
On my original Greddy build when I spun like a **** on new slicks and cut a terrible 2.0 60ft I trapped 122mph, when I cut a 1.6 60ft, I trapped 126mph and that was with me letting off slightly.
edit-to answer your question about YOUR trap, well that is tricky, because I know you are already bumping limiter in 4th before crossing the line, so if you hook and have to shift to 5th, it may kill or help your run depending on how fast you shift. I avoid shifting into 5th like the plague, and so should you.
Old 06-27-2011, 10:11 AM
str8dum1
str8dum1's Avatar
i never saw much correlation. I could blow my launch and maybe trap 1-2 mph slower. thats why trap is a good indication of hp. hard launch/soft launch, they only thing that changes alot is your ET.
Old 06-27-2011, 10:21 AM
SmurfZ
SmurfZ's Avatar
your trap speed wont get higher with a better 60ft time. only your et will show some difference.
more traction = lower mph/faster et
Old 07-13-2011, 07:39 PM
djamps
djamps's Avatar
+1
Think about it... a slower ET gives you more time to accelerate to a higher trap.
Old 07-13-2011, 08:36 PM
Alberto
Cranky FI Owner
Alberto's Avatar
A faster ET from a car laying its power down will trap higher than a guy sitting there spinning not accelerating in a Fi VQ platform.
We had a thread like this long ago, myself and IIRC Briguymax agreed, better 60ft, better trap.
Take it for what its worth.
Old 07-23-2011, 01:51 PM
SE5spd
SE5spd's Avatar
I agree with that
Old 07-23-2011, 02:19 PM
03threefiftyz
03threefiftyz's Avatar
Disagree. More traction (particularly early) results in greater acceleration (higher resulting trap). I always trapped higher as my 60' dropped. Having more initial traction>than the resulting loss from friction IMO.
Old 07-23-2011, 02:44 PM
2bad240
2bad240's Avatar
i agree, when i had a 1.64 60' i trapped 91 in 1/8th
when u had 1.62 60' i trapped 93
my 1/4 mph stayed pretty close to being the same.
Old 07-23-2011, 05:19 PM
3hree5ive0ero
Retired Admin
3hree5ive0ero's Avatar
Theoretically, more traction should yield a higher trap, but that doesn't always happen in the real world.
Old 07-23-2011, 05:50 PM
Nealoc187
Nealoc187's Avatar
Originally Posted by djamps
+1
so if that's the case I am going to pour a bunch of oil all over the track next time and see if I can trap 200mph because I'll have more time to accelerate! Awesome.
p.s. you're completely and utterly wrong.
Old 07-23-2011, 05:53 PM
Z1NONLY
Z1NONLY's Avatar
All from one night at the 1/4 mile track a few years ago...
2.092=98.45
2.107=97.98
2.129=98.98
2.205=98.39
2.053=98.47
2.077=98.28
Old 07-23-2011, 06:46 PM
tranceformer95
tranceformer95's Avatar
Looking over some of my times, quicker 60ft usually gives a higher 1/8 mile trap speed.
Old 07-24-2011, 01:55 PM
SE5spd
SE5spd's Avatar
Better 60ft = you're traveling faster at the 60ft mark = you're traveling faster at the 1/4 mark.
Old 07-25-2011, 11:25 AM
Alberto
Cranky FI Owner
Alberto's Avatar
I'll be sure to use this as an example next time it comes up around me.
Old 07-26-2011, 02:14 PM
marra23
marra23's Avatar
+1
This does not make sense
I'm no expert but my logic says....you don't have time, you need acceleration because the distance stays the same.
If you took longer, you spent more time not accelerating at full potential. Every split second lost due to traction, slow shifting etc leaves you with less momentum and distance to gain speed in.
So how can you reach a higher speed over the same distance if your car spent less time accelerating at full potential?
Obadabot
06-18-2023 11:31 PM
lapham3
10-07-2022 03:15 PM
XM 1
07-10-2022 07:44 AM
3vilbunny
07-18-2017 05:10 PM
Quick Reply: How does 60ft time effect your trap speed??
