weld-in oil drain bung
Old 06-06-2011, 06:48 AM
the_coupe
the_coupe's Avatar
Default weld-in oil drain bung
which is the ideal weld-in aluminum fitting to put into the oil if/when i need it for an oil return?? might as well do this while i have the oil pan off for the motor build....
Old 06-06-2011, 09:28 AM
sportbiketed
sportbiketed's Avatar
I would just go with a spacer like this one: http://www.jimwolftechnology.com/cus...asp?PartID=449
Old 06-06-2011, 09:36 AM
ImWeeZzel
ImWeeZzel's Avatar
^^^What he said, AAM, Stillen makes one too. I would go the extra mile and add stainless steel lines, if you dont have them already.
Old 06-06-2011, 10:02 AM
Just buy a pan or spacer with oil ports in it.
Old 06-06-2011, 10:18 AM
str8dum1
str8dum1's Avatar
-12An aluminum
http://www.anplumbing.com/shop/index...dept=Weld!_Ons
weld to upper oil pan
Old 06-06-2011, 12:28 PM
the_coupe
the_coupe's Avatar
id much rather have a bung welded as the fittings are mad cheap and my boy does all my welding for free. so -12AN is the size to go with......thanks str8dum1
lapham3
10-07-2022 03:15 PM
XM 1
07-10-2022 07:44 AM
apex locator
07-23-2021 02:27 AM
burglapfd
12-06-2020 01:04 PM
Quick Reply: weld-in oil drain bung
