Unlocking door opens trunk??
This just started yesterday...
I got to a friends house after a 30 minute drive and while the car is still on, the trunk popped itself open while I'm sitting inside the car. While it was popped open, I could hear the actuator triggering itself like someone was pressing the unlock button for the trunk over and over. If I closed the trunk it would just open itself up again but that thankfully stopped today.
Now, the trunk stays closed but if I press the door unlock button on the fob or the door, it activates the trunk actuator and pops the trunk open. Also noticed my windows aren't moving up that extra 1/3 inch when I close the doors with them rolled up.
What's going on here??
I had this same problem. It was the hatch release switch (the rubber covered button under the hatch). The switch contacts get stuck in the hatch open position. I just kept pressing the release button, and eventually the contacts in the switch released. If it happens again, I guess I'll have to replace the switch. Hope this helps.
just started my own post kindof similar to this.
https://my350z.com/forum/maintenance...k-problem.html
also, after reading your problem, i noticed that my passenger window wasn't automatically going up/down when the door opens like its supposed to either. i dont have a fob, so im still not sure as to what is the problem.
Same trunk opening issue.
When I unlock my car door from the inside the trunk also opens. Then it goes hay wire and I hear the acuator keep trying to open the trunk. The only time it stops is when I hit the arm button. Anyone?
It also could be a fault in the trunk button or its wiring causing it to be always pressed so whenever the car is unlocked it is trying to unlatch the hatch.
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
04-04-2016 07:52 AM
