i need help...when i press down my clutch car stalls
Old 04-15-2011, 06:35 PM
350Z-GREEKSTER
350Z-GREEKSTER's Avatar
Default i need help...when i press down my clutch car stalls
ok guys i am new to this but i need your help...
so i just got my car from storage a few weeks ago (i live in canada) and i just i stalled a tanabe exhaust... i went to show off a bit and then god probably punished me and next thing i know is that my car stalled for no reason....so i drove it back home slowly and noticed that when i press down the clutch my car stalls.........its a 2005 350, i have a exedy clutch and flywheel........almost new so idk wat it is THANKS
Old 04-15-2011, 06:40 PM
surfcity40
surfcity40's Avatar
limp mode.
Old 04-15-2011, 06:41 PM
surfcity40
surfcity40's Avatar
funny, but still limp mode.
Old 04-15-2011, 06:43 PM
350Z-GREEKSTER
Old 04-15-2011, 06:46 PM
dmroberson
dmroberson's Avatar
limp mode... or maybe flywheel is too light?
Old 04-15-2011, 06:49 PM
350Z-GREEKSTER
ok thanks but theres also a squeeking noise when i press the clutch.....
Old 04-15-2011, 06:50 PM
350Z-GREEKSTER
how do i know if my flywheel is to light?
Old 04-16-2011, 05:51 AM
glenns280
glenns280's Avatar
Take it out an do 10 curls if your arm is not hurting its too light.....
Old 04-16-2011, 09:29 AM
winchman
winchman's Avatar
OK, if it's "limp mode", what's telling the ECU that the clutch is being pressed down?
It can't be the clutch switch, because that makes it impossible to start the engine when the pedal ISN'T down, and there's no other wiring going to it.
If it's stalling when you first move the clutch pedal down, it might be the ACSD switch. It turns off the cruise control if you step on the clutch to keep from revving the engine. I think that would let the engine go back to idle, not kill it.
Try adding a little throttle when you press down on the clutch. If it's a too-light flywheel, the extra rpms will keep it from stalling.
Old 04-16-2011, 09:43 AM
Quattro
Quattro's Avatar
^Standard procedure.
Where do you usually idle at? Try raising the idle up a bit, it might be dipping too low due to the decreased weight. Are you also running a lightweight pully?
Old 04-16-2011, 10:36 AM
winchman
winchman's Avatar
Does the squeaking noise come from the dash/footwell where the clutch pedal is, or from under the car where the clutch is? Does it happen when only with the engine running, or when the engine is stopped, too?
Old 04-16-2011, 12:34 PM
dmroberson
dmroberson's Avatar
IIRC if under 10lbs, there isn't enough inertia to keep the engine running, so the tach will bottom out, and the car stalls... or something like that.
Any idea how much your flywheel weighs? I have the ACT Prolite flywheel and I think it's 13lbs or so
Old 04-16-2011, 03:39 PM
350Z-GREEKSTER
ok thanks for the help guys........i dont know how what is my flywheel because it came with the car...all i know is that its a exedy stage 1 kit...clutch and flywheel.......also the squeeking noise dose it only when i press the clutch......... the car was running fine for a like a year so...i think it might be the bearing
Old 04-17-2011, 12:26 PM
T3K
T3K's Avatar
If i remember correctly stage 1 exedy combo comes with a steel FW, so the weight wouldn't be a problem.
Darkspy
09-07-2015 09:09 PM
Quick Reply: i need help...when i press down my clutch car stalls
