location of fuel filter
Old 04-11-2011, 11:32 AM
halfrice
halfrice's Avatar
Default location of fuel filter
is the fuel filter on the z external or inside the gas tank?
Old 04-11-2011, 11:41 AM
DavesZ#3
DavesZ#3's Avatar
It's built into the fuel pump and is not user servicable.
Old 04-11-2011, 12:04 PM
amr_electron
amr_electron's Avatar
There's no filter, But there is a mesh screen around the inlet to the fuel pump, and the fuel pump itself has a built in filter that is not replaceable. If the filter gets clogged, you will need a pump replacement.
Old 04-11-2011, 12:50 PM
halfrice
halfrice's Avatar
im getting what feels like a lack of fuel, trying to source the problem, any other ideas what could be causing it? injectors? car has about 25k miles and i do track it about 5 times a year
car is base model and no traction control, tends to happen when i pin the throttle while turning. Was at the track yesterday, never happened while on the track but after the event on the way home started happening again, seems to happen only with driving on the street
Old 04-11-2011, 12:54 PM
350z006
350z006's Avatar
It's not too difficult to get the fuel pump assembly out; I've done it dozens of times....just need some time in the Derail garage if you know what I mean, lol...
It could be your fuel pump too, or dirty injectors....are you leaning out?
Old 04-11-2011, 02:12 PM
VO...
Administrator
VO...'s Avatar
+1...
Old 04-11-2011, 02:55 PM
djamps
djamps's Avatar
This is pretty common with Z/G's if you have under a half tank of gas and hard cornering...poor tank design... have you tried on a full tank?
Old 04-12-2011, 12:36 AM
halfrice
halfrice's Avatar
maybe its time to upgrade to a walboro, well see if that fixes the problem
tank was at 3/4 full so shouldnt be the gas tank, plus car was at 1/4 beginning of my track session and didnt have any problems.
Old 04-12-2011, 08:05 AM
Long rt corners will cause a starve under 1/2 tank, the starting a session at 3/4 is not big deal but a track condition the car gets about 8 MPG , so its actually tearing thru gas pretty quick.
I'm thinking about modding to a dual pump system, one pump on each side. Screw fuel starve issues.
Old 09-20-2020, 04:56 AM
g0lfball3R
g0lfball3R's Avatar
doesn’t that saddle bag arrangement over the shaft already have 2 pumps? Secondary feeds the main with line to the engine. Sounds like maybe you want both pumps directly feeding the heads? Likely extra fuel line & other stuff.
MM'08_350Z
04-22-2021 09:42 PM
Tochigi_236
09-27-2015 03:40 PM
Quick Reply: location of fuel filter
