HELP!! Mt Top Won't Close!!
Old 03-26-2011, 01:56 PM
04ZCONV
04ZCONV's Avatar
Default HELP!! My Top Won't Close!!
Hey guys, I have an 04 convertable and when I put the top down, the deck lid or cover or whatever it's called, wont lock down in place. i have to get out.... push om the corners RIGHT behind the doors so the cover lid will lock and the warning indicator light will go off... Can anyone PLEASE give me the easy low cost good news on this situation and any other info regarding this. Thanks in advance...
Old 03-26-2011, 03:19 PM
AJCaron12
AJCaron12's Avatar
Change Mt top to My top
Old 03-26-2011, 05:12 PM
04ZCONV
04ZCONV's Avatar
thanks AJ..
Old 03-26-2011, 05:23 PM
AJCaron12
AJCaron12's Avatar
Originally Posted by 04ZCONV
thanks AJ..
Old 03-26-2011, 05:39 PM
tblunt1
tblunt1's Avatar
No idea how old your top is, but since I replaced mine last Oct if it's cooler (Under 70) I have to hit open/close several times to get the top to compact down enough to close. No idea if it's because of the newness or the cold or a combo of both. If you're trying to put it down and the temps are like here (90 miles south east of you if you're in Memphis by profile) the cold could be the factor. Hopefully that's all it is. Not a expert by any means as I just bought mine last July. Hope it's just the cold and nothing mechanical for you..
*edit*
I will mention on the 'cold' part, it was 75ish to 80 a couple days in the past 2 weeks, top opened/locked like a charm right off, next day was 66 in the morning when I went to goto work and had to up/down 4 or 5 times to get fully down why I say it might be the cold for you also...
Old 03-26-2011, 05:54 PM
04ZCONV
04ZCONV's Avatar
Excellent point tblunt. Yes I am here in Memphis. I will see about your call with the temp. I never thought of that before. However, The days in the very past weeks that you mentioned is ONE day in particular that it was 80 up here and the lid still wouldnt close. I wonder if the last little inch just needs to be pushed down in there a little better. I say this bc it takes damn near all of my weight dist. through one hand to get it to close. Of corse it doesnt do that when the top goes up . Only with the crammed top in its "case" lol... Any other thoughts?
Old 03-26-2011, 06:12 PM
tblunt1
tblunt1's Avatar
Hmm, besides the obvious stuff I'd be clue less on anything mechanical wise. I'm assuming that you've checked to make sure nothing fell into the compartment etc, have your wife open the top and while it's folding stand beside the car and make sure it's not bunching up. Basically stuff you've probably already done.
Might look around the posts about lubing the joints/hinges. There were some posts on here possibly in the maintenance thread but can't recall exactly. I've no clue what type of lubricant or grease recomended though.
Wish I could offer more advice but I'm just as new to all this as you
Old 03-26-2011, 06:22 PM
04ZCONV
04ZCONV's Avatar
Lmao.... actually yet ANOTHER good idea that my 7 year education diddn't lead me to think about...lmao.. I'll look as soon as I get home and let you know... Thanks..
Old 03-26-2011, 06:24 PM
AJCaron12
AJCaron12's Avatar
Is this similar to your situation?
https://my350z.com/forum/350z-roadst...ompletely.html
Old 03-26-2011, 06:28 PM
AJCaron12
AJCaron12's Avatar
Or this? I don't have too much experience with verts so I can't exactly relate to your problem.
Classification: BT08-029
Reference: NTB08-10
Date: December 18, 2008
SOFT TOP COVER DOES NOT FULLY OPEN
APPLIED VEHICLES:
2004 - 2008 350Z Roadster (Z33)
IF YOU CONFIRM
When trying to open the top, it will not fully fold down into the storage area.
ACTION
Replace the elastic straps with the part listed in the Parts Information section of this bulletin.
Replace the convertible top seals if necessary with Part Number 97066-CE40A.
PARTS INFORMATION
CLAIMS INFORMATION
IMPORTANT: The purpose of "ACTION" (above) is to give you a quick idea of the work you will be performing. You MUST closely follow the entire Service Procedure as it contains information that is essential to successfully completing the repair.
SERVICE PROCEDURE
1. Retract soft top cover about 90 degrees.
2. Remove front center finisher.
3. Remove front center retainer.
4. Remove A-link retainer (both sides).
5. Remove the clips from the notch in A-link (both sides). See Figure 5.
6. Remove the soft top cover from the frame at the 1st bow and fold back at the 2nd bow.
^ Make note of the location of double-sided tape which will be replaced when reinstalling parts.
7. Drill out the rivets and remove the elastic strap attached to the 2nd and 3rd bow (both sides).
IMPORTANT: Be careful not to damage the soft top cover, protect the area as necessary.
8. Install the elastic straps.
9. Reinstall all the components in reverse order of removal.
^ Make sure to apply double-sided tape to the first bow.
10. Check to make sure this issue has been resolved.
Old 03-26-2011, 06:42 PM
04ZCONV
04ZCONV's Avatar
Thanks a lot AJ!!! The first link is not my problem. That sounds like a closing lock down of the top to the decklid. I have the problem relating to the 2nd posting. When my top crams itsel into the top storage area, the lid that closes over it (whatever t f it's called) will not click and lock tight into its "position". Thus leaving an indicator light on the dash and u know the rest of the story.. I'll look into all of these suggestions.. I F'n love forums...
Old 03-31-2011, 04:47 AM
sluggoZ
sluggoZ's Avatar
So what's the latest?
Old 03-31-2011, 06:23 AM
mestisoZ
mestisoZ's Avatar
Make sure its warm out.. found that out the hard way lol
Old 04-05-2011, 08:54 AM
Wingnutt
Wingnutt's Avatar
I got my 2005 Z just a month ago and am having the same problem as you with the top. I took it back to the dealership and they also said that the cooler weather had alot to do with its operation.
Old 06-08-2011, 08:57 PM
lyccheng
lyccheng's Avatar
Default My similar convertible top problem.
My problem is slightly different from your. My convertible top has been service and replace about three time through manufacture warranty. It finally open and close properly. However, I notice the back of the rear roof storage lid on the driver's side would not align with the passenger's side. I don't want to take it back to those f**ker at Nissan. If I have to, I want to find out why did that happened. Doesn't anyone has the same kinda experience?
Old 07-30-2011, 09:09 AM
charlie_rdstr_Z
charlie_rdstr_Z's Avatar
Having this issue now...
Old 07-30-2011, 03:24 PM
sluggoZ
sluggoZ's Avatar
Most Nissan dealerships subcontract their top problems to an independent shop.
Old 07-31-2011, 09:22 AM
britalia
britalia's Avatar
"When my top crams itsel into the top storage area, the lid that closes over it (whatever t f it's called)"...that would be a Tonneau cover.
Old 08-08-2011, 06:59 PM
charlie_rdstr_Z
Long time no see SluggoZ. I talked to a mechanic over the phone at Performance Nissan. I asked if they take it out and they told me they would do it themselves.
Old 08-09-2011, 05:43 AM
sluggoZ
sluggoZ's Avatar
I'm still around charlie!
My dealer sent my ZR out when they replaced my top....so did others here on this forum........no need for this...Name:  bsmeter.jpg
Quick Reply: HELP!! Mt Top Won't Close!!
