Twin turbo build fabrication/pics
Old 01-09-2011, 09:28 AM
Boosted Performance
Vendor - Former Vendor
Boosted Performance's Avatar
Originally Posted by IslandZavage
Damn.... now that's a water slide.... where is that?
I live 15 minutes away from the worlds largest indoor water park:
http://travelwithkids.about.com/od/w...mwaterpark.htm
Old 01-09-2011, 09:36 AM
thawk408
thawk408's Avatar
Originally Posted by str8dum1
ya i always wondered why kits like my SFR or SP didnt use a little longer header to use the space a little further back. its rather cramped.
your kit will really take money outta the other guys pockets!
Use a bigger turbo with a V-band housing, and you will understand the PITA part of designing a kit like this. If you go further back on the driver's side the header flange hits the frame, and then compressor housing hits the slave cylinder. Then if you rotate the turbo, it hits more ****. We switched my car to solid motor mounts to prevent any unwanted flexing, since everything fit so close.
The shop working on my car, built my kit basicly from scratch using twin 6062s v-band exhaust houseings. The 5-bolt houseing makes everything fit better, but doesn't flow as well.
More has been done since this pic. It is basicly done, just waiting on a few things.
Old 01-09-2011, 09:37 AM
ImWeeZzel
ImWeeZzel's Avatar
keep up the good work man, suscribed for progress
Old 01-09-2011, 10:33 AM
str8dum1
str8dum1's Avatar
welcome to lag city. a dry 150shot of nitrous til 5500rpms might be my next step. 5bolt is a complete PITA. I wish I had done V-band at the exhaust and turbine inlet.
Old 01-09-2011, 10:39 AM
ttg35fort
Professional
ttg35fort's Avatar
Nice work, Sasha!
The only concern I would have based on the pictures is the location of the air intake for those of us who live in wet climates.
I like the twin turbo setup because of the increased efficiency of twin compressors on our motors. This setup should be good to achieve in excess of 600 whp. At 600 whp, the GT2871 compressor should be operating around 72% efficiency (Edit, I originally grabbed the wrong efficiency number on the map, it appears to be 72% in lieu of 74%, which is still pretty good). My calculations show approximatley 15.5 psi (1.07 Bar) of boost, which is a 2.07 pressure ratio, and 32.5 lb/min. of airflow per turbo.
Edit #2 - At 650 whp, pressure ratio will be somewhere around 2.24 with 35 lb/min. of air flow, which still is within the operating range of the compressor, maybe around 70% efficiency or so. There might be an issue with the exhaust flow at a 0.64 A/R for the turbine housing that MAY make achieving 650 whp difficult. We won't know without a dyno run. I have a 0.64 A/R turbine housing on my 3071 turbos, and I'm not entirely sure I'll make my 750 whp goal on my setup with that A/R value due to back pressure, which can result in reversion of the exhaust gases back into the cylinders. We'll see. I figured I would try 0.64 A/R first, and if that does not get me where I want to be, then move to a 0.86 A/R turbine housing, which of course, will mean delaying spoolup.
Here is the compressor map. You can plot the pressure ratio and airflow on the map. It is slightly above the ideal operating range, but offers a great tradeoff for quick spoolup:
Old 01-09-2011, 11:08 AM
thawk408
thawk408's Avatar
Lag city...lag this lag that blah blah blah. Car has been on the dyno and the lag is not bad at all honestly. And when you rev to 8k, I could care less about power below 5k. Quick fix = downshift.
The 5 bolt housing is physically smaller, so I dont see how it could of been any harder then the V-bands.
Oh, and the car made 750rwhp dd on 22psi....
Old 01-09-2011, 11:19 AM
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
Curious... You use Precision turbos on your single kit. Why the change to Garrett turbos for this twin setup?
Also, have you considered the new Borg Warner EFR? That would be cool to see in an application like this.
Old 01-09-2011, 11:25 AM
roger22
roger22's Avatar
Don't Stein, get the APS TT setup Bro....
Old 01-09-2011, 11:32 AM
CRIDDA
CRIDDA's Avatar
Another innovative project by Sasha In for the win
Old 01-09-2011, 12:11 PM
grimm66
grimm66's Avatar
Good thing I just paid off the car, now it's time for the right kit to come along.... (HINT HINT..... WINKING ALSO)
Old 01-09-2011, 12:39 PM
str8dum1
str8dum1's Avatar
getting the 5 bolts in past the bends in the downpipe is a *****.
750 is a good pump gas/meth tune. did you use any race gas yet?
Rude, from all the pics, it looks like those EFR turbos a much bigger than same wheel sizes from other makers. Have you seen one in person to compare external dimensions?
Old 01-09-2011, 12:48 PM
thawk408
thawk408's Avatar
It was on $2.40 E85 and a very conservative tune . There is another 30rwhp or so at the same psi.
PMed, so we do not ruin the OP's thread.
Old 01-09-2011, 12:54 PM
thawk408
thawk408's Avatar
Also, I would warn against ever trying to use a BW turbo in this location. My original idea was to use the Bullseye modified BW s262's, but after taking deliver of one we quickly realized they were almost impossible to fit. The way their exhaust housings are make it very difficult to work with the turbo in location specified by the OP.
The turbine inlet is taller then on a compared Precision/Garett, also the center cartridge is longer. We even machined a T31 housing from apgturbos.com to work with my s262, but it still would not fit beside the transmission. We scrapped the idea of using the BWs, and that is the reason I personally went with the Precision turbos.
Old 01-09-2011, 03:49 PM
Boosted Performance
Originally Posted by ttg35fort
Nice work, Sasha!
Thank you, and to the other comments.
I use the same filter location on the ST kit as this TT set up, and have not had issues with it at all. I have driven in some heavy rain as well, and when I got home took the intake pipe off to check for moisture, and there was none.
As far as turbine housings, a .64 should work very well for most applications. If one wanted the GT30's I would go suggest the .86 hot side.
To truly find out what the potential is, I will have to find somebody with a built motor willing to push the limits.
The reson I went with Garrett is the more compact compressor cover. The smalles you can get on a PTE turbo is a B size cover. Either way both are quality proven turbos, and should deliver in either the TT or ST forms.
EFR's as somebody already mentioned have too much crap attached, and would not fit at all.
Old 01-09-2011, 04:37 PM
ttg35fort
Professional
ttg35fort's Avatar
Sasha, you are on the right track and I commend you for this build. The fact is that you are doing it, and as so, you will be teaching the rest of the community. Thank you! This build looks awsome!
Old 01-09-2011, 04:48 PM
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
I see... So a B size compressor housing (2.5" inlet & 2" outlet) is really too large to fit in your application?
I looked up the dimensions of the EFR. As was pointed out, they are significantly longer than a comparable Precision or Garrett turbo. Here are the dimensions for their smallest sizes of the EFR line.
Old 01-09-2011, 05:05 PM
Boosted Performance
The B compressor cover has a larger over all diameter. The GT28 turbos are a bit smaller, but still have a 3" inlet and a 2" outlet, same as the B covers.
GT28 cover:
B compressor cover:
Both have a 3" inlet, but you can see how much wider the B cover is over the GT28 cover.
Garrett GT28 turbos can be had with an even smaller cover, the same one they use on the GT25 line of turbos. That thing is very small, have a look at how it compares to the T25 turbine housing:
I could have put this (GT25r) cover on the turbos, and called it a day. The reason I did not do that, is do me wanting to offer the GT3076R as the top dog turbo. It has a 57mm wheel, and it would not fit in the tiny GT25 series compressor cover. I think APS uses these small covers, with some custom machining to fit the larger compressor wheel.
Old 01-09-2011, 05:29 PM
  #38
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
Thanks for the clarification Sasha.
According to SP's website, Precision's B cover has a 2.5" inlet and their E cover has a 3" inlet. Is that incorrect? If the GT28 housing has a 3" inlet and the Precision B cover has a 2.5" inlet, it could give the illusion in that pic comparison that the Precision housing has a larger overall diameter.
http://www.spracingonline.com/store/...urbo_5557/3688
Old 01-09-2011, 06:35 PM
  #39
Boosted Performance
Well, I must correct myself on this whole compressor cover size comparison.
Took a couple of pictures, left is the GT28 with a 3" inlet and on the right is the PTE B compressor cover with a 2.75" inlet. This makes it look like the compressor is a bit larger overall, even though it is not:
The outlet on the B cover is a bit longer, but that really is no big deal in this case.
The big difference here is T25 vs T3 (although this is a rather large .82a/r T3);
I did however try to see how the 5557 T3 .82 a/r with a B cover would fit:
Passenger side:
Driver side:
Definetly possible to make it work, but a bit more of a PITA. The T3 does come with the following a/r options: .48 .63 .82., so a nice variety, but I would never go with a .82 a/r, as it would spool very late in the RPM.
Here is proof that the PTE B cover is not 2.5" or 3.0":
Old 01-09-2011, 07:31 PM
  #40
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
Thumbs up
Cool!!! Thanks for taking the time to look into this and for showing great comparison pics between the two. Much respect for that!
You definitely have some nice turbo options available to you.
Quick Reply: Twin turbo build fabrication/pics
