Sikky 350z/G35 LSX swap
Old 05-16-2011, 07:01 AM
  #441
Royal_T
Royal_T's Avatar
I am using a KRC Drift Power Steering pump for my PS.. **** is legit... Also have their tensioner too..
Old 05-16-2011, 06:27 PM
  #442
Havok_RLS2
Havok_RLS2's Avatar
Originally Posted by bbs350z
so i would imagine the ls a/c unit would just need custom lines, which mates directly to our a/c condensor? also, if we spliced the ac wire on the z harness into the ls harness (its only 1 wire for the z harness) and using the condensor, couldnt we control the ls a/c with the factory controller?
Correct!
or even better, if we could fabricate a mounting solution for the z a/c condensor in the ls a/c location we wouldnt need any wiring riffraff, just custom lines, to which it should operate like stock then id assume. lines would be fairly easy to hide as well (inside the fender)
No need to reinvent the wheel. K.I.S.S (Keep is stupid simple)
Old 05-17-2011, 12:38 AM
  #443
bbs350z
bbs350z's Avatar
Just got my sikky kit in today, this stuff is top notch!! quality is excellent, and the packaging was superb!
also sent them my wiring but requested they leave the factory z a/c wire connected for future use.
starting my assembly tomorrow
Old 05-17-2011, 06:58 AM
  #444
Cass007
Cass007's Avatar
I expect full pictures of what plugs into where and what all the sensors on the LS are for and where they are located... basically anything and everything that will make my install go more smoothly. Thanks!!
Old 05-17-2011, 07:19 PM
  #445
bbs350z
bbs350z's Avatar
will do, doin a full write up of the install once i get the wiring back from sikky!
Old 05-17-2011, 07:31 PM
  #446
bbs350z
bbs350z's Avatar
on a sidenote, just found out with my pro performance intake or any other non-ls1 intake (such as ls2/6, etc) the factory ls1 coolant line connecting the 2 front ports to the 2 back ports will not work unles your grind the manifold (not reccommended) so an ls6 style setup is required, which simply blocks off the back ports and connects the 2 fronts together. you can find more info here
http://www.ls1.com/forums/showthread.php?t=155716
i feel its little details like this that slow down builds, and if we can get a bunch of tips/tricks together, people can have their projects together and running quicker with less hesitation or trouble!!
Old 05-18-2011, 04:04 AM
  #447
Royal_T
Royal_T's Avatar
^^ Yeah I know what you mean.. I ordered mine with my FAST 102 intake
Old 05-18-2011, 12:38 PM
  #448
Cass007
Cass007's Avatar
+100 on that, especially since some of us are going to be DIY for the majority of the project. I can get the stuff in the car, its the wiring and such that will hold me back for sure.
Old 05-18-2011, 11:19 PM
  #449
bbs350z
bbs350z's Avatar
just got done with the sikky master cylinder install. was incredibly simple. the only pain in the *** was getting the nisan rod back in with the snap ring.
alsp for you guys goin with aftermarket intake mani's, use a thin head bolt so itll clear. i used hex flat top bolts, they are m8 x 1.25 x 30
Old 05-19-2011, 04:05 AM
  #450
Cass007
Cass007's Avatar
pics of everything or it never happened
Old 05-19-2011, 07:58 AM
  #451
bbs350z
bbs350z's Avatar
^will do. i only have my tele at the moment for pics. whatever you do, i advise getting a set of snap ring pliers and some extra lube... ooh lala
Old 05-19-2011, 10:06 AM
  #452
Royal_T
Royal_T's Avatar
Good info... When you going to do your build thread.
Old 05-19-2011, 01:43 PM
  #453
Cass007
Cass007's Avatar
I will purchase the pliers... already have the lube for the wife
Old 05-19-2011, 01:53 PM
  #454
2004Black350z
Exhaust Whore
2004Black350z's Avatar
haha
Old 05-19-2011, 10:20 PM
  #455
bbs350z
bbs350z's Avatar
motors goin in next week so ill start it up then probably
dirty man, you seem like a diy kinda guy, find a use for those pliers
Old 05-20-2011, 08:28 PM
  #456
10-E-C-350Z
10-E-C-350Z's Avatar
Looking forward to joining the LS ranks.
Old 05-22-2011, 08:42 AM
  #457
QTB
QTB's Avatar
Seems like there are a lot of LS builds going on right now. By the end of summer I'm guess there will be a lot of good info and write ups out there.
Old 05-22-2011, 09:16 AM
  #458
Quamen
Quamen's Avatar
There is actually quite a bit of information out there already for swaps but the mods won't create a swap forum to help organize the information. That is why there are so many of the same threads on swapping LS's, 2JZ's, RB's, SR's, VR's and VH's.
Old 05-22-2011, 10:29 AM
  #459
dikspiel
Chestons Toilet
dikspiel's Avatar
A LS swap FAQ might need to be created
Old 05-22-2011, 02:43 PM
  #460
bbs350z
bbs350z's Avatar
At the very least! I agree with qwamen on getting a swap specific section
Quick Reply: Sikky 350z/G35 LSX swap
