What dif fluid used for clutch type lsd?
Old 09-11-2010, 08:47 AM
halfrice
halfrice's Avatar
Default What dif fluid used for clutch type lsd?
Been running Motul PA90 ever since i had my nismo lsd installed, noticed that ive been overheating the fluid and cant afford a dif cooler at the moment and was curious what everyone else was using. Been leaning towards trying out torco heard alot of good things about them, but wanted to see what people use for track use. Thanks
Old 09-11-2010, 09:59 AM
I'm just running Amsoil 80w140
Old 09-12-2010, 07:54 AM
Fixxxercask
Fixxxercask's Avatar
I am running Redline 75-90, but I need to step it up to a heavier weight since I've been doing more racing. I was considering the AMSoil. Heard a lot of good things about them.
Old 09-21-2010, 07:42 PM
halfrice
halfrice's Avatar
you guys running the additive or just gear oil?
Old 09-21-2010, 10:29 PM
My OS Giken specifically say not to run a additive. So it should depend on your diff.
Old 09-22-2010, 02:18 AM
Fixxxercask
No additive. What kind of additives can you run?
Old 09-22-2010, 06:20 AM
scotts300
scotts300's Avatar
I run the PA90 with the finned diff cover without issue:
http://www.importpartspro.com/nirefidico07.html
I've found I have to change the fluid every few events though.
Old 09-22-2010, 02:02 PM
halfrice
halfrice's Avatar
i have the nismo finned dif cover as well and change my fluid after every other event, but noticed it overheating on some of the smaller more technical tracks ie streets of willow.
halfrice
halfrice's Avatar
every brand has their own additive, supposed to help reduce chatter.
Old 09-22-2010, 02:24 PM
scotts300
scotts300's Avatar
I don't run any additive either, as they are supposed to chatter.
How can you tell it was overheating? I do get some blowoff sometimes, but typically attribute that to me overfilling it when I change the fluid (since I have the car jacked up in the rear).
Old 10-11-2010, 02:11 PM
halfrice
halfrice's Avatar
usually happens near end of the session in the afternoon, but when i do a left to right or vice versa turn transition i hear a loud thunk noise when the car shifts weight, sounds and feels like the diff, so was going to try different fluids to verify.
Old 10-14-2010, 06:55 PM
12AutoX
12AutoX's Avatar
I had bad experience with Royal Purple, Nismo fluid is so-so, and Motul has been very good. I don't know about overheating, just in terms of noise and smoothness. What are you guys doing to overheat your fluid? I run in AZ and NM in 100 degree weather for 15-20 minute sessions and never have a problem. I only have a Nismo diff cover.
lapham3
10-07-2022 03:15 PM
burglapfd
12-06-2020 01:04 PM
sherm
04-11-2020 05:21 PM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: What dif fluid used for clutch type lsd?
