Best 350z Non-brembo brake pads
Old 05-26-2010, 09:08 PM
dj_saki
dj_saki's Avatar
Default Best 350z Non-brembo brake pads
Does anyone have suggestions for which brake pads to purchase for a 350z non-brembo for street driving? Should I just stick with OEM, Hawk HPS, or something else?
I assume ceramics are the best choice due to the lack of brake dust and brake pad/rotor life. Thanks.
Old 05-26-2010, 10:26 PM
Mike@Blackline
Mike@Blackline's Avatar
for street driving, id say oem
Old 05-26-2010, 10:46 PM
350ZTheStandard
350ZTheStandard's Avatar
If there is a possible chance of doing a open track day I like hawk pad's, otherwise OEM would do just fine.
Old 05-27-2010, 01:42 AM
dmroberson
dmroberson's Avatar
+1. OEM are good pads for normal street driving. I personally am using ProStop Ceramic pads... just because they're low dust, and don't squeal. Not sure about the life though, claims to be longer than OEM, but we'll see...
Old 05-27-2010, 03:31 AM
davidv
davidv's Avatar
Finally a brake pad thread. Lets get this subject out in the open for discussion.
Old 05-27-2010, 04:51 AM
Ruthless18x
Ruthless18x's Avatar
I'd stick with OEM, but I use to run PMU B-Force pads on my stock brakes and loved them.
Old 05-27-2010, 05:31 AM
glenns280
glenns280's Avatar
lmao
Old 05-27-2010, 06:03 AM
lilpud
lilpud's Avatar
uhhh i still wouldn't run stock pads just for the fact that, if you need to stop and your runnin anywhere near 100 the brakes will start to fade out on the 1st hard stop.
Old 05-27-2010, 06:27 AM
tylerxfire
tylerxfire's Avatar
hawk hps /thread
Old 05-27-2010, 06:36 AM
drivessidewayz
drivessidewayz's Avatar
Hawks aren't made for low speed stops, so for daily driving OEM is better imo. Hawks would be better if you plan on stopping from 100 like lilpud mentioned.
Old 05-27-2010, 06:43 AM
scotts300
scotts300's Avatar
Hawk makes a variety of pads, from street to heavy tracking. You can not make a blanket statement like this and be accurate. I autox a street pad because they have great initial bite and low dust, but use a serious compound for tracking.
OP - are you looking for fronts or rears or both? I have some extra street rears since I am in the middle of changing rear brake set-ups. I may have a front set also, I could look, but I have used Hawk HPS, NISMO, and Axxis Ultimate for street use with great success.
Old 05-27-2010, 07:26 AM
plumpzz
plumpzz's Avatar
Stock is too dusty. I liked axxis ultimates and hawk HPS. I did not like oem.
Old 05-27-2010, 07:51 AM
SoarVigor
SoarVigor's Avatar
I don't care what anybody says, ceramics are always better. Track-proven by me.
/thread
Old 05-27-2010, 07:52 AM
StopTech
Vendor - Former Vendor
StopTech's Avatar
You're all crazy. StopTech performance pads. Higher bite and higher temperature range than the HPS. Less dust and less noise than the HP+ or Axxis ULT pads.
If you wanted to do a 100mph run with these, you can. If you wanted to take your car to the track with these, you can do it without having these pads fade.
If you have a full blown high HP car running really sticky tires like slicks, then you probably aren't running stock brakes, and should be running full race pads.
Old 05-27-2010, 08:57 AM
scotts300
scotts300's Avatar
Absolutely agreed on all accounts.
If you have a mildly-built, 260rwHP car running really sticky tires like slicks (or DOT Hoosiers), and the ***** to deep-brake to make up ground on fast cars, then you probably aren't running stock brakes, and should be running full race pads.
Fixed! (Though I'm still going to try the ST perf pad given their good value and see how many events they last - I will report back). Maybe they'll be just enough when coupled with your larger ST40 front kit and Brembo rears with cooling.
Old 05-27-2010, 01:01 PM
350ZTheStandard
I am kinda amazed you are singing the praise of ST pads, it's not like you sell em. Do you also sell Centric products, the lesser end of the brand ***** ST?
http://www.centricparts.com/index.ph...brake-products
This announcement falls quickly on the heels of
last year’s purchase of StopTech, the leader in balanced brake upgrades.
Old 05-27-2010, 03:34 PM
05Z33
05Z33's Avatar
I'm currently on the same set of Akebono pads that I installed back in 2006. No noise or dust and it's my boosted daily driver.
Old 05-27-2010, 03:44 PM
StopTech
StopTech's Avatar
LOL.. you don't have to take my word for it.
http://www.m3forum.net/m3forum/showthread.php?t=303748
http://forums.nasioc.com/forums/show....php?t=1890908
We only sell through our distributors who also have access to the Centric pads.
Old 05-28-2010, 12:38 PM
Tsukuba-Z33
Tsukuba-Z33's Avatar
s-cribed
Old 05-28-2010, 12:59 PM
350ZTheStandard
Why are you not talking up Centric products, less profit??? I am sure they have their own propaganda site also.
Quick Reply: Best 350z Non-brembo brake pads
