Lug Nuts Wont Stay Tight and Fall Off
Old 03-23-2010, 06:39 AM
gidiup
gidiup's Avatar
Default Lug Nuts Wont Stay Tight and Fall Off
Never experienced this in my entire life. The lug nuts on my aftermarket rims won't stay tight. They loosen themselves up and fall off. The best is while driving the steering wheel shakes horrible and all you hear is a grinding noise. The rims are over brembo brakes so I don't understand. Any help would be very much appreciated. Can't drive the Z until I get this resolved. Thank you
Old 03-23-2010, 06:41 AM
huyrua
huyrua's Avatar
Did you put hubcentrentric rings on the aftermarket rims?
Old 03-23-2010, 06:43 AM
gidiup
gidiup's Avatar
I didn't get any with the rims. Would that make the difference? I have them as flush as possible against the rotor. Plus do I have the get the ones made for that rim.
Old 03-23-2010, 07:42 AM
Z04
Z04's Avatar
are they the OEM lugs? if so they are different than aftermarket acorn-style and will not seat properly.
Old 03-23-2010, 07:47 AM
NismoZ_840
NismoZ_840's Avatar
Are you torqueing the lugs to spec (~80-90 ft/lb)? Are you getting at least 7-8 lug rotations? Any damage to the stud threads? What is your lug size? Are you running spacers? If so what size, type, and any mods to the studs? Any lubricants on the lugs (ie. they shouldn't have any)?
350Zappa
350Zappa's Avatar
Oem are 60deg cone angle. If your wheels aren't they won't hold. Give more details on your wheels.
Old 03-23-2010, 07:50 AM
Wu-Watt
Wu-Watt's Avatar
Hub rings.....
Old 03-23-2010, 08:14 AM
qqqqball
qqqqball's Avatar
could say f *** it and put locktight
Old 03-23-2010, 08:16 AM
scotts300
scotts300's Avatar
Are you using a torque wrench? What torque are you tightening them to?
Old 03-23-2010, 08:24 AM
gidiup
gidiup's Avatar
OEM lugs wouldn't fit. The holes are to small. They OEM lugs fit in but I can't get anything on the lug to tightn them. The rims are Montegi Touges. I'm past the point of torque'n them off to 90 and on to tight'n them to 100. The lugs I'm trying to use now and shelf brand from Advanced Auto Parts. They were the only ones I could find to fit. Np spacers are installed on the Z. Only the Brembos that came with the car.
These are the rims. I bought them off a guy on a forum.
Old 03-23-2010, 08:38 AM
davidv
davidv's Avatar
The seat of the nut fits the wheel properly correct? Photos helpful.
Nut is open or closed?
Old 03-23-2010, 08:46 AM
Nexx
Nexx's Avatar
buy some new lugs man. maybe your studs are stripped a bit?
Old 03-23-2010, 08:54 AM
Entaille
Entaille's Avatar
pull a wheel off that this is happening on and check if the studs stripped at all. check the lugs for any sort of damage from all this etc..
Old 03-23-2010, 08:57 AM
gidiup
gidiup's Avatar
Here are the lug nuts I'm using right now. These are Dorman Wheel Lug nuts. Or I should say trying to use.
Old 03-23-2010, 08:58 AM
gidiup
gidiup's Avatar
Love to buy some new one but just don't know what to buy.
Old 03-23-2010, 09:07 AM
DavesZ#3
DavesZ#3's Avatar
The $64,000 question is: What pitch are the threads? 1.25 or 1.5? The stud on the Z are 1.25. It's possible to make the mistake and put on 1.5 pitch which won't screw on or torque down properly.
Old 03-23-2010, 09:10 AM
gidiup
gidiup's Avatar
They are 1.25. I thought the same thing. Triple checked it.
Old 03-23-2010, 09:12 AM
gidiup
gidiup's Avatar
The reason I'm using those lugs is because they were the only ones that would fit inside the rim and get a wrench on them. The studs aren't stripped. Looked at them again last night. Nobody has ever heard lugs falling off the car or coming loose while driving. The steering wheel goes insane when it happens.
Old 03-23-2010, 09:13 AM
gidiup
gidiup's Avatar
I'm to the point of just selling the rims and tires. Getting something new.
Old 03-23-2010, 09:21 AM
tylerxfire
tylerxfire's Avatar
ur problem is that u need to get different lug nuts that fit correctly..easy as that..
conical tuner style and not from advanced auto or something on the shelf u find there, lol..order the correct ones from a vendor
Quick Reply: Lug Nuts Wont Stay Tight and Fall Off
