Tires Size For My 2004 Nissan 350Z
Old 08-30-2009, 07:50 AM
CeMeTeRy
CeMeTeRy's Avatar
Default Tires Size For My 2004 Nissan 350Z
hi,
i have just bought new tires for my 2004 Nissan 350Z. The issues is that as you know the rear tires size are different from front ones as rear are 225/50/17 and front are 235/50/17. I couldn't find 235/50/17 i found 235/55/17 & 225/50/17 so i bought the 225/50/17. Is there any problem with that? I bought brand called Toyo
Thx
CeMeTeRy is offline
Old 08-30-2009, 08:01 AM
DavesZ#3
DavesZ#3's Avatar
It depends - does your Z have TCS or VDC? Since your rears are the same OD as your fronts, you might have issues with TCS or VDC kicking in unexpectedly.
DavesZ#3 is offline
Old 08-30-2009, 08:10 AM
davidv
davidv's Avatar
225/50/70. What is 70? mm? cm? JDM inches?
davidv is offline
Old 08-30-2009, 08:38 AM
CeMeTeRy
CeMeTeRy's Avatar
DavesZ#3
i have Traction Control System and i drove it for a while it drives the same a bit better cuz of the new tires
CeMeTeRy is offline
Old 08-30-2009, 12:20 PM
isktarum
isktarum's Avatar
I think you're mixing up what size you have on front/rear....what you have listed there makes no sense.
isktarum is offline
Old 08-30-2009, 12:29 PM
+1 , OP get back and straighten out your post.
terrasmak is online now
Old 08-30-2009, 12:31 PM
ParanoidAndroid
ParanoidAndroid's Avatar
70?!
ParanoidAndroid is offline
Old 08-30-2009, 02:11 PM
TheFarmer
TheFarmer's Avatar
Originally Posted by CeMeTeRy
hi,
different from front ones as rear are 225/50/70 and front are 235/50/70. I couldn't find 235/50/70 i found 235/55/70 & 225/50/70 so i bought the 225/50/70. Is there any problem with that?
Wow. And I thought 20s were big.
TheFarmer is offline
Old 08-30-2009, 02:34 PM
Shertown Turbo
Shertown Turbo's Avatar
lol someone should photoshop some 70's on a Z to show him what that looks like
Shertown Turbo is offline
Old 08-30-2009, 06:21 PM
neox
neox's Avatar
Does your Z look something like this?
I think you might have tire rubbing issues.
neox is offline
Old 08-31-2009, 12:46 AM
CeMeTeRy
CeMeTeRy's Avatar
just like it
com'n it was a mistake...
the last number should be 17 not 70
CeMeTeRy is offline
Old 08-31-2009, 05:29 AM
davidv
davidv's Avatar
just like it
This is not a combination that I world recommend, but if it works it works.
davidv is offline
Old 08-31-2009, 05:48 AM
isktarum
isktarum's Avatar
since there is more than a 3% increase in overall diameter bumping the rears up from 235/50/17 to 235/55/17, you may have issues with TCS/VDC. if you already have them on your car, drive around for a while doing lots of turns in a parking lot or something and see if you notice anything with the traction control kicking in. If so, you may need to try a different tire size for the rears.
isktarum is offline
Old 08-31-2009, 08:58 AM
CeMeTeRy
CeMeTeRy's Avatar
what i got for my car for both sides are the
225/50/17 and it works fine. it's written on the
door that i should use for front i guess 235/50/17
but i used the same as the rear which is 225/50/17.
CeMeTeRy is offline
Old 08-31-2009, 09:48 AM
davidv
davidv's Avatar
So you are running 225/50/17 all around? Assume with 17 inch wheels you do NOT have VDC. Its OK the car will be fine.
davidv is offline
Old 08-31-2009, 01:06 PM
neal@tirerack
Vendor - Former Vendor
neal@tirerack's Avatar
The 55's will be an inch taller than the oe 50 series. May cause a rubbing/vdc issue.
neal@tirerack is offline
Old 08-31-2009, 01:13 PM
CeMeTeRy
CeMeTeRy's Avatar
exactly ,, i do have the traction system but things are just fine thx Davidv
CeMeTeRy is offline
Old 08-31-2009, 01:38 PM
jdudzik
jdudzik's Avatar
I use 255/45/17 because i could not get the Goddyear F1's in the stock rear size.
The 255 will bulge out more but it didn't bother me very much. But this tire is MUCH closer to the stock diameter, which is what you should try to achieve
here is a pic to explain...
I would STAY AWAY form the 225/55/17 as the TCS will not be happy. You will need to disengage it everytime because it will kick in when you least expect and get rear eneded.(trust me on this one)
I hope you like oversteer because 225's on the rear of even a stock Z will create a more tail happy car.
jdudzik is offline
Old 08-31-2009, 03:20 PM
davidv
davidv's Avatar
I have those tires on 17 inch wheels for autocross. Damn good tires.
davidv is offline
Old 09-01-2009, 11:18 AM
CeMeTeRy
CeMeTeRy's Avatar
they look cool but don't you think they will make the car a bit low specially for street bumps? specially here where i live there are a lot and the size i have makes it great on them otherwise; the grils erea will be damaged
CeMeTeRy is offline
JjL
East Canada
06-12-2019 03:04 AM
10-04-2015 07:55 PM
Cam2662
09-22-2015 05:00 AM
EnjukuRacing
09-11-2015 08:34 AM
Quick Reply: Tires Size For My 2004 Nissan 350Z
