DIY: Rear Strutbar Cover Removal & Paint
Old 02-13-2009, 07:09 PM
mcarther101
mcarther101's Avatar
Default DIY: Rear Strutbar Cover Removal & Paint
The last owner of my car did a horrible job painting my rear strutbar cover, and it had bubbles everywhere. So I finally got around to refinishing it. I messed up once by not using primer which caused the paint to have a strange texture to it.
Tools you will need:
Small hands/interior panel poppers/flathead screwdriver
Dremel
Microfiber towel
BIN Shellac-Base Primer
Enamel paint of your choice (I used Dupli-Color auto spray flat black)
Clearcoat (I used Rustoleum Painter's Touch Matte Clearcoat
Directions:
1) Remove the rear strutbar cover with either small fingers, or a flathead screwdriver. Pop away the surrounding panels with your fingers or a flathead screwdriver. It's best to just find a loose part of the plastic to pry away with your hands so you don't scratch anything. Remove in the order of A, B, C, D (not visible), and then the strutbar cover (E).
It may be difficult to remove, but don't worry the last two things holding it down are not screws or bolts. They are two snaps shown here:
2) Then take out the Z emblem by cutting away at the 5 plastic bubbles behind it, and simply poke it out from the back side.
3) Once you have the cover off, sand it down with 200 grit paper longways (in the direction of the dimples). Then sand it until it's smooth with 400 grit sandpaper in the same direction. Take a microfiber towel and wipe away all the dust.
4) Apply thin coats of primer, one every couple minutes or so until you're content with the even coverage of primer. Spray from about 12 inches or more away, and shake can occassionally between sprayings. It should look like this when primered:
5) Let the primer dry for an hour. Sand it lightly with 600 grit paper in the same direction as before. Wipe away the dust with a microfiber towel.
6) Apply thin coats of paint in the same manner as the primer until coverage is even and complete. It should look like this:
7) Apply two layers of clearcoat similarly. (At first I tried not clearcoating, but it wasn't realistic because dust would settle and get stuck on the dried paint). I used rustoleum painters touch matte clearcoat.
Optional, and recommended to remove imperfections in the smoothness of the paint:
8) Allow clearcoat to dry (I waited a day), then wetsand with 1000+ grit sandpaper VERY LIGHTLY. You don't want to dig back into the paint through the clearcoat. Wipe away the dust and water with a microfiber towel.
9) Spray on one more layer of clearcoat and allow it to dry. Wallah, Nice and smooth!
Let the clearcoat dry, and re-attach the Z emblem with glue on the back side where those 5 holes are. Then just put it all back together!
Old 03-02-2009, 09:22 AM
Drewsum
Drewsum's Avatar
Mine in black
Old 03-02-2009, 09:39 AM
lgear080
lgear080's Avatar
Mine looks busted too. Always wanted a tonester-esque cf cover,
but this came out great... good work
Old 03-21-2009, 07:49 PM
GQstyles
GQstyles's Avatar
"where's bin laden" lol
Old 03-21-2009, 09:40 PM
JasonZ-YA
JasonZ-YA's Avatar
good job...
Old 05-30-2011, 08:41 PM
VengefulHitman
VengefulHitman's Avatar
great DIY tutorial, i plan on using this for when i touch up the strutbar cover on my Z.
thanks a lot
Old 05-30-2011, 08:57 PM
midz350
midz350's Avatar
Anyone else thought the HP printer in the last pic is a 350z front bumper
Old 06-07-2011, 07:38 AM
agunter33
agunter33's Avatar
^^^^ wow, I totally did
Old 06-07-2011, 07:51 AM
ZS14RR
ZS14RR's Avatar
Thinkning about doing this but not sure.
Old 10-06-2011, 11:40 AM
Itzcashew
Itzcashew's Avatar
Did mine in black but i used 400, 1000 and 2000 for the sanding. Needs to go back and redo it with a different color. I did mine in flat black and it just looks gross in the daylight.
Old 12-28-2011, 11:02 PM
Slaughter3fifty
Slaughter3fifty's Avatar
Did mine today. This made taking it apart a lot easier.. I painted mine red though, and the z is black.. to match the black / red I got going on with the car. I'll put pics up when I can get to a computer.
Old 12-30-2011, 08:03 PM
Slaughter3fifty
How mine turned out.. might take more pics during the day so you can really see it better lol (ignore the filthy trunk)
Old 01-06-2012, 10:17 PM
Z7757
Z7757's Avatar
Did mine red and black aswell. was a pain to tape off the little black squares, but well worth it
Attached Thumbnails DIY: Rear Strutbar Cover Removal & Paint-z7757-351439-albums-garage-black-ninja-8034-picture-re-installed-43641.jpg   DIY: Rear Strutbar Cover Removal & Paint-z7757-351439-albums-garage-black-ninja-8034-picture-re-installed-43642.jpg
Old 02-19-2012, 08:37 PM
DViper0020
DViper0020's Avatar
I did mine a few weeks ago when I painted some of my interior trim. The previous owners of my Z didn't care about scraping the strut bar, because that thing looked awful. The chrome plating on the Z in the center of the strut bar was wrinkling a bit too, so I figured I should do something about it. In the pics the bar looks white, but it's silver. It actually isn't as reflective as the stock silver that was on the strut bar either, which I like.
Old 03-11-2012, 10:39 AM
Noor93y
Noor93y's Avatar
Great instructions man, ill post mine up shortly
Old 03-11-2012, 10:41 AM
Noor93y
Noor93y's Avatar
Yours looks great man i like that it kinda looks like white thats a great twist (i know you said it was silver.) Im also just wondering what that shift **** is?weighted?
Old 03-11-2012, 11:32 AM
DViper0020
DViper0020's Avatar
Thanks. I love the way it looks. Definitely a great simple diy that makes your car look much better. (Especially if your strut cover is all scratched up) I got the shift **** on Amazon I think. It was real cheap, I liked the way it looks, and it has a similar weight to the stock shift ****. It isn't as tall as the stock one either.
Old 03-13-2012, 06:07 PM
aznxdope
aznxdope's Avatar
Anybody know where I can buy the whole OEM strut + emblem?
Old 06-24-2012, 05:53 PM
LJF
LJF's Avatar
awesome! didnt think of this. Mine is all pealing up. I just need some more funds and i can get a simple body kit.
Old 06-24-2012, 06:01 PM
taywan
taywan's Avatar
Nice job
. I just got a cf one for mine.
Quick Reply: DIY: Rear Strutbar Cover Removal & Paint
