best way to clean oxidized headlight??
Old 09-14-2008, 05:22 AM
matix101vz
matix101vz's Avatar
Default best way to clean oxidized headlight??
my headlights are getting oxidized and turning a little yellow, what is the best cleaner to make them look new/newer. is there a special plastic cleaner or is there a home remedy thats better
Old 09-14-2008, 05:57 AM
crazydelicious
crazydelicious's Avatar
Meguiar PlastiX
Old 09-14-2008, 05:58 AM
davidv
davidv's Avatar
3M makes some great products for plastic. Problem is that you cannot get inside the lense to clean condensation and dirt.
Old 09-14-2008, 10:50 AM
ZSpectrum
ZSpectrum's Avatar
Sip on an orange pad at 2000rpm on a rotary finish with 106ff orf a on a white at 1400 then 11000 rpm used that on a 2004 g35 sedan last night.
Old 09-14-2008, 11:01 AM
WhiteNoiz
WhiteNoiz's Avatar
Ive had great results with plastic X. If its bad enough, you may need to wet sand first with very fine sand paper, 2000 grit (use light pressure). Then follow up with the plastic polish.
Old 09-14-2008, 12:33 PM
UofA350Z
UofA350Z's Avatar
PlastiX FTW!
Old 09-14-2008, 12:35 PM
Jay'Z
Jay'Z's Avatar
Porta cable/polish.....
Old 09-14-2008, 03:00 PM
matix101vz
matix101vz's Avatar
thanks everyone
Old 09-14-2008, 03:19 PM
blackz123
blackz123's Avatar
Originally Posted by crazydelicious
Meguiar PlastiX
+1
Old 09-15-2008, 06:23 PM
yella
yella's Avatar
I used SIP with Orange pad came out brand new...it was really bad...
a month later it came back...so i guess you gotta keep polishing since the clear is gone...
Old 09-15-2008, 07:00 PM
mr.elite
mr.elite's Avatar
Originally Posted by UofA350Z
PlastiX FTW!
+1 love it!
Old 09-16-2008, 11:32 PM
BRONZEE
Club Moderator
BRONZEE's Avatar
I used to use PlastX, but found it didn't last more than 2 weeks in the exceptionally harsh climatic conditions in NZ.
For over a year and a half I've been using the Turbo Wax range including the Headlight Restoration. I used this product the first time in January, and I've only just re-did them this month, that's pretty damn good going. It's quite a gentle way to clean the oxidation off our silly plastic headlights, and it's highly effective and doesn't take much effort, even better.
http://www.turbowax.com/home.php?xid...9a46dbdf3d2643
Definitely worth trying IMO.
Uriyo_
09-08-2021 08:46 AM
Dsowe
02-17-2021 10:38 AM
Colombo
11-09-2020 10:27 AM
_bit
10-02-2015 07:49 AM
JGee450
09-30-2015 04:32 AM
Quick Reply: best way to clean oxidized headlight??
