Air Conditioning intermittent problem
Old 07-22-2008, 07:56 AM
JCat
JCat's Avatar
Default Air Conditioning intermittent problem
2004 mt ~ 40,000 miles.
Lately, mostly when the -Z- is hot from sitting in the sun, my air conditioner will not blow cool air when I first turn it on. This did not happen before.
After I drive for a short while, it will kick on.
It is an intermittent problem, however, it seems to be getting worse.
Have you had this problem? What might be causing it?
Thanks,
JCat
Old 07-22-2008, 09:00 AM
quakerroatmeal
quakerroatmeal's Avatar
I have never been in any type of car, that has sat in the sun for a while immediately blow cool air when first turned on. It would normally take me maybe a minute to start cooling down.
Old 07-22-2008, 09:19 AM
JCat
JCat's Avatar
I understand what you are saying. I have owned this car for 4 years and I assure you that there is a problem, the air conditioner will not work for a long, long time.
Sometimes it will shut down and stay off (no cool air) totally for 15 minutes while I'm driving.
Old 07-22-2008, 04:36 PM
R-TuneZ
R-TuneZ's Avatar
are you saying the compressor is not working or an electrical issue...? maybe its time for a recharge/service of the a/c?
i have to wait about a minute or two after start-up before i get cold air coming out of my vents...
Old 07-22-2008, 04:49 PM
surfcity40
surfcity40's Avatar
is the compressor turning? It's just ready for service probably.
Old 09-03-2008, 05:40 AM
Brrcats
Brrcats's Avatar
Thanks,
JCat
I'm having a similar problem, my air conditioner will cut out intermittently, ex. I was on the way to dinner last night with the A/C on and all the sudden the air got really hot, hotter than the outside ambient air. It happened this morning as well on the way to work. The A/C will work again on and off, but never for very long.
I have an 04.5 ~ 32k on the dial.
Old 09-06-2008, 02:21 AM
SOSEXZ
SOSEXZ's Avatar
I had this problem today with my 04 with 35K. I hope there is an easy fix. When I turn my car on, it cools down really fast and the air is ice cold. But sometimes when im driving, it will stop blowing out of the vents. I play around with the fan speed **** and the **** you adjust to choose where to air should come out of and it usually fixes it. Could it be a bad connection someplace?
Old 09-16-2008, 03:32 PM
mkg5150
mkg5150's Avatar
Mine is intermittent and seems to occur when hot and very VERY humid. A/C always kicks on when selected, then after a variable time it kicks off, air feels humid and ambient to slightly warmer. Note: a/c light stays on. One thing I've noticed is that if I have the temp set at 75 and it kicks off, it comes back on faster (sometimes immediately) if I raise the temp to 80. Of course, 80 w/out humidity is far better.
Anyhow, I figure something in the system is overloaded by dehumidifying gross amounts of Charleston SC air. I'm hoping one of the guys here have dealt with this and can share the fix. BTW, if the anwser is leave Charleston I think it's worth it....
Old 09-16-2008, 07:44 PM
JCat
JCat's Avatar
[quote=mkg5150]Mine is intermittent ....
Two posts since you joined in 2003 ? ? ?
Old 09-16-2008, 09:42 PM
nismo_nate
nismo_nate's Avatar
same thing is happening to me... today driving to the gym, it would shut off.. then i would play with the ***** a bit turning them on/off.. defrost and so on.. then it would go back to normal.. i don't know if messing with the ***** did anything.. but yeah.. any solutions?
05 base ~ 20k
Old 09-16-2008, 09:44 PM
350z2k3
350z2k3's Avatar
350z's have air conditioning?
Old 10-12-2008, 04:38 PM
laurentj23
laurentj23's Avatar
Mine is doing the same damn thing!What the hell is wrong?!
Old 10-12-2008, 04:41 PM
Jarred@Z1
Z1 Motorsports
Jarred@Z1's Avatar
sounds like AC amp. The little white box behind the buttons and shifter cover.
Old 10-18-2008, 07:15 PM
garbud
garbud's Avatar
Default Intermittent AC
Anymore info on this problem? Does anyone know the cost of an AC Amp assembly?
Garbud
Old 10-20-2008, 09:06 PM
sallreen
sallreen's Avatar
The air conditioning blows cold air when the car is idle. After driving for about 10 minutes it starts to blow warm air. If you stop and wait and wait for 10 minutes it will start to blow air cold air again. In the winter you will be able to use the air conditioner to defog the car without any problems it blows cold air to keep the car defogged.
Sally
social marketing
Old 06-01-2010, 09:15 AM
JCat
JCat's Avatar
Update -
I have been dealing with this problem since 6/2008. About 8 months ago, I took the -Z- to the Nissan dealer. They said it was a bad sensor that was located in the blower box and that it would cost me $600 for them to tear the dash apart and replace it.
I didn't believe them.
The A/C only blew cold air when the car was moving.
I finally figured it out . . . . one of the two radiator fans was not working. AND it turns out that this is a common problem, so much so, that Nissan warrants the fans for 86 months.
No my car did not run hot. The temperature gage indicated everything was fine.
Now that the problem is fixed, I cannot say I feel stupid for not diagnosing it earlier.....because the Nissan folks didn't either.
You might occasionally check and see if both your radiator fans are working.....before the Nissan extended warranty expires.
I'm a cool cat now.
Old 06-01-2010, 09:45 AM
jtabraham
jtabraham's Avatar
what dealership did you go to?
Old 06-01-2010, 10:08 AM
JCat
JCat's Avatar
Team Nissan in Lithia Springs.
When the Service Manager and Tech told me it was a sensor in the blower box, I futilely searched for it in the Service Manual, with no success. I can just imagine what other disasters would have happened if I had let them take my whole dash apart.
Old 06-01-2010, 10:13 AM
winchman
winchman's Avatar
What's an "AC amp"?
If the AC blows cold air intermittently, it can't be the compressor or the sealed system. When those fail, they don't mysteriously recover.
It's something in the electrical system related to the compressor clutch, the door in the heater box, or the radiator fans.
Old 06-01-2010, 10:41 AM
JCat
JCat's Avatar
Originally Posted by winchman
What's an "AC amp"?
When my radiator fan failed, the refrigerant flowing thru the air conditioner condensor was not getting cooled (enough).....therefore the air in my passenger compartment was not getting cooled. . . .
Pic of condensor (it sits in front of the radiator) :
Quick Reply: Air Conditioning intermittent problem
