Help My Check Engine Light Keeps Flashing!
Old 05-14-2008, 11:51 PM
ycdevil
ycdevil's Avatar
Default Help My Check Engine Light Keeps Flashing!
Hey well i was driving my Z and all of a sudden my check engine light started flashing then i would atay on then flash again. on and off o and off. damn what can it be. plase help!!
Old 05-15-2008, 03:33 AM
sloppymax
sloppymax's Avatar
flashing cel typically represents a misfire. get the code (autozone, advance auto) pulled to identify which cylinder is misfiring then you can inspect the coil, plug, etc.
Old 05-15-2008, 06:10 AM
QuadCam
QuadCam's Avatar
slppy is right. it is usually an individual cylinder misfire. IIRC, the CEL will flash and you can count the flashes which will tell you which cylinder is misfiring. I don't know if that's true or not; I just use a OBD2 scanner to tell me what codes I have.
Old 05-15-2008, 07:59 AM
ycdevil
ycdevil's Avatar
so is it a simple fix?
Old 05-15-2008, 08:35 AM
sloppymax
sloppymax's Avatar
there is no way of knowing without the code. i would bet on a coil or plug but anything would just be a guess.
Old 12-07-2010, 04:35 PM
ddc665350ztt
ddc665350ztt's Avatar
i have the same prob. the only code i get is p0300. i troubleshot it down to all my driver side cylinders were not firing! i changed the cam sensor, checked the coils, plugs and injectors. everything check out good. the next thing i need to change is the crank sensor.
Old 12-07-2010, 05:26 PM
djamps
djamps's Avatar
Simplest problem is a fried coil pack. Let it idle and unplug/replug each coil pack one by one. If one of them being unplugged doesn't affect the idle, that is your bad pack/cylinder. Other than that it could be anything from wiring issues to a bad injector.
Uriyo_
09-08-2021 08:46 AM
MM'08_350Z
04-22-2021 09:42 PM
350z82
10-01-2015 06:25 PM
Sleeper_Z
09-30-2015 10:25 AM
Quick Reply: Help My Check Engine Light Keeps Flashing!
