Washer fluid reservoir leak?
Old 04-18-2008, 08:53 AM
Mike2048
Mike2048's Avatar
Default Washer fluid reservoir leak?
I had a rather large puddle of washer fluid on my garage floor the other day, so I took the inner wheel well cover off to look at the tank. It looked intact, I checked connections hoses and pumps. I poured some fluid in, did not notice as much as a drop so I filled it up a bit more. No visible leaks. I put everything back together, took the car for a drive before going to bed for the night. In the morning I was greeted by yet another puddle. I did not use the washer fluid on my drive. What gives? A really, really slow leak somewhere?
Old 04-18-2008, 08:59 AM
SpeedRcr
SpeedRcr's Avatar
you might have a small crack or the line that feeds the wipers might be loose...if its under warranty take it in
Old 04-18-2008, 10:06 AM
Mike2048
Mike2048's Avatar
No warranty... I'm going to take the tank out completely later on today to look for a crack. But man, I did not even see a drop... just wierd
Old 05-01-2008, 05:36 PM
pbenchin
pbenchin's Avatar
Default Did you solve the mystery?
Check where the pump mounts into the reservoir. If it's anything like my BMW 325i, the pump dredge slides into a strainer cup. Make sure the pump is fully seated into the strainer cup. It's possible that the strainer needs to be replaced also, as it serves as a gasket. The pump could be bad, or you could have a hairline crack in the reservoir. Let the reservoir leak, until it stops leaking. Then that will be telling where the leak is coming from. Good luck!
lapham3
10-07-2022 03:15 PM
burglapfd
12-06-2020 01:04 PM
Twenty4
01-17-2016 01:20 PM
derekinthez
South East
09-28-2015 06:35 PM
Quick Reply: Washer fluid reservoir leak?
