Door handle removal...
Old 02-27-2008, 12:40 PM
ni$mo350
ni$mo350's Avatar
Default Door handle removal...
Just spent the last 45 minutes looking for directions on how to remove my door handles and came up with nill... 33 pages on the search for door handle removal by title REDICULOUS. Someone please point me in the right direction for a DIY or just tell me. Thanks
Old 02-27-2008, 09:08 PM
03Zilverstone
03Zilverstone's Avatar
Open door pull out two rubber plugs. Unbolt to 10mm bolts. Wiggle handle until it works out. Release lock and latch cables.
Old 02-27-2008, 09:13 PM
Kuruma-san
Kuruma-san's Avatar
^lol
Old 02-28-2008, 02:42 AM
Control 350z
Control 350z's Avatar
lol the job takes less time than he spent searching
Old 02-28-2008, 09:37 AM
ni$mo350
ni$mo350's Avatar
Measure twice cut once... Rather safe than sorry and I like to be prepared when I work on my car. I wouldn't have known it was a quick job unless I asked and as stated above I searched the endless pages but came up with nothing thanks
Old 02-28-2008, 11:36 AM
mdracer76
mdracer76's Avatar
QFTMFW.. thanks for searching first. I would have done the same thing. The indexing on this site does kinda blow.
Old 02-29-2008, 05:18 AM
sluggoZ
sluggoZ's Avatar
Driver Door:
1. Open door.
2. Locate & remove 2 rubber grommets right behind the door handle.
3. Unbolt the 2, 10mm bolts holding the handle in & be careful not to drop the bolts down the door.
4. Pull up & out on the door handle, you'll see that it was attached by 2 metal rods.
5. Flip the yellow or pink clip up to release the metal rod.
6. Unbolt the electronic key lock.
Passenger Door:
Same as above except there are no metal rods to disconnect & no electronic door lock done. Easier!
Old 04-22-2008, 02:05 PM
KGsZ
KGsZ's Avatar
Just what i was looking for. Thanks everybody lol
Old 04-22-2008, 03:19 PM
ni$mo350
ni$mo350's Avatar
No thank YOU for searching
Old 10-26-2011, 11:28 PM
Mcutali
Mcutali's Avatar
Default re
a body shop wanted to charge me 150 remove and paint black, i laughed, i aked how much if i remove, they replied 50.. deal.. 100 to remove 4 bolts 2 rods and keylock lol
Old 11-16-2011, 07:54 AM
slo_latino
slo_latino's Avatar
^ you should have painted it yourself!! its even cheaper lol. or wrap them in carbon fiber vinyl like i did, turned out great!
Old 11-16-2011, 08:11 AM
sluggoZ
sluggoZ's Avatar
Old 01-17-2013, 09:57 AM
downte47
downte47's Avatar
this post helped me alot thanks guys
350Z_Al
10-29-2020 07:44 PM
04-04-2016 07:52 AM
10-04-2015 07:55 PM
Quick Reply: Door handle removal...
