APP Sensor - P2122 & P2138 - CEL
Old 11-24-2007, 03:54 PM
benwa02
benwa02's Avatar
Default APP Sensor - P2122 & P2138 - CEL
Does anybody know anything about this part, where it is located, experience dealing with it, know why it may have went bad?
Car drove fine last night, started it up today and the check engine light was on. Did the visual check everything, couldn't find anything so I started to drive to AutoZone but I could not accelerate at all. The car could barely move out of its own way. Getting to 40mph took forever. So I am trying to get to the nearest AutoZone and after a stop light I can all of a sudden hit the gas and drive normally. Get to AZ and they tell me the following:
P2122 - APP Sensor 1 Low Input
Probable Causes:
1 - Failed APP Sensor 1
2 - Open or short circuit condition
3 - Poor electrical connection
P2138 - APP Sensor Performance Condition Fault
Probable Causes:
I drive a 2006 Z. I am going to check it out tomorrow and try to find the part, so any help would be appreciated.
Thanks.
Old 11-24-2007, 04:18 PM
Eazzy
Eazzy's Avatar
If Im not mistaken thats a TPS Code
Throttle Position sensor Input /output circuitry
Old 11-24-2007, 04:31 PM
DavesZ#3
DavesZ#3's Avatar
P2122 Accelerator Pedal Position Sensor
P2128 Accelerator Pedal Position Sensor 2
Because the Z is drive-by-wire, the gas pedal is connected to position sensors, not a cable to the throttle plate.
Diagram to locate the sensor:
Old 11-24-2007, 04:44 PM
benwa02
benwa02's Avatar
Thanks man...I would have been looking under the hood the whole time.
Any clue why I would get 2 codes for the same part? Or why this would fail?
The only thing that sticks out to me is that:
1) it got pretty cold last night (10-20 degrees idk)
2) when i shut the car off the night it worked good I had to turn the key to accessories to get the windows to go up and accidentally went too far for a split second, like i was turning it on. I dont know if this would eff it up but all I know is next day it wasnt running right.
Also, is there wires connected to this that are running under the hood, that I should check also?
Old 11-24-2007, 04:49 PM
DavesZ#3
DavesZ#3's Avatar
Two code for two sensors. Check your PM box.
Old 11-24-2007, 04:57 PM
Eazzy
Eazzy's Avatar
That must be a rheostat type sensor that contols current flow
The two codes are different probs with the sensor...2122 is D switch for Low Output and 2138 is Correlation between B/C circuits
Unplug it and clean/lube with Dielectric Grease first---
Old 11-24-2007, 05:12 PM
benwa02
benwa02's Avatar
thanks a ton. you guys have been uber helpful.
never would have thought to look under the dash for a sensor... i woulda been pulling my hair out tomorrow looking for this thing.
Old 12-02-2007, 04:18 PM
benwa02
benwa02's Avatar
brought it to nissan and they checked everything out and couldn't find anything wrong with the sensor. must have been some random thing hopefully.
cars been driving fine since and they said that the code was prolly on its way out because i had driven 86 miles since the code and everything is working fine now.
Old 12-11-2007, 09:16 AM
DJMatrix1067
DJMatrix1067's Avatar
actually if i remember right, i heard that you are not supposed to turn the key on and off real fast.
i remember reading in the service manual that the throttle body and APP hone themselves or something right when ur turn the car on or off. if you listen carefully you can hear them moving when u first turn the car on. if you ever disconnect your throttle body from the harness, you have to go through a process to rehone the two.
sounds like you may have cut off the power to the two sensors while you were rolling up the windows. just a stab in the dark though
Old 02-09-2008, 05:05 PM
eagletanggreen
Got Track!!!!!
eagletanggreen's Avatar
Did you get this fixed??? I just this this code today.
Old 02-09-2008, 05:14 PM
benwa02
benwa02's Avatar
technically, no.
i brought it to the dealer after like 88 miles (they could tell me how long after the code popped that i kept driving)...i think after a certain amount of miles (100, cuz the guy said i was getting close) the light ends up going out if the problem doesn't exist anymore
they checked everything out...the sensor, the grounds nothing came back faulty so it must have just been a freak thing. it was driving fine since...its off the road now for the winter though
Old 02-10-2008, 12:34 PM
eagletanggreen
Got Track!!!!!
Mine keeps doing it but only a WOT around 3K anything after that and the car is fine. If I drive it like a normal person the car is fine, its only when I go WOT under 3K and boost starts to build??? Any one please chime in??
Old 10-03-2009, 09:51 AM
JAM3Z
Phenom
JAM3Z's Avatar
I just threw this code. Do I just need to replace the sensors?
Old 10-03-2009, 11:20 AM
benwa02
benwa02's Avatar
Maybe, maybe not.
Mine ended up being a strange glitch for a half hour and was checked by the dealers like I mentioned and they couldn't find anything. Has been driving fine ever since.
Does your car run weird? If not, try clearing the computer and see if it comes back or keep driving it for a little and see if it will clear itself.
The part is underneath the dash, above the pedals somewhere... should be a diagram here... you'll see.
Old 10-03-2009, 01:26 PM
JAM3Z
Phenom
JAM3Z's Avatar
Originally Posted by benwa02
Maybe, maybe not.
The car has been acting weird for a long time. But since it's my second car, I'm able to put it off. However, the problem has persisted for a while, and has still not cleared itself up. I'll clear the computer again and see what happens.
Old 10-03-2009, 01:38 PM
JAM3Z
Phenom
JAM3Z's Avatar
Ok, I cleared the ECU. Things were going great for a couple of minutes, and the code came back up and the throttle went back to being unresponsive. WTF?!
Old 10-20-2009, 11:04 AM
Ragingbull350Z
Ragingbull350Z's Avatar
I'm having the same problem. I'm throwing all kinds of codes dealing with the APP and TPS sensors. I've searched this problem on the site, and so far it seems to be somewhat of a common problem but all with different solutions(if they find one). This is definitely an annoying issue, especially when the throttle dies rolling through an intersection.....FML
Old 02-04-2010, 08:23 AM
kof0127
kof0127's Avatar
That happened to me guys, when I was waiting almost at the intersection to turn make left turn the pedal went bad, my girl was in the car she almost broke with me, (JK) that would be bad if that really happen. she told me to get some better brake since I like to drive fast and drifting and ****, and get the pedal done, what happen it dies when I was drifting things like.
But the problem solved after I turn off and turn on the car, sometime have to turn off many time and turn on many times then the car runs again, it only happens once after a month or two. when i looked under the dash all the wires are looking good can't see anything wrong. damn it
Old 04-23-2010, 04:05 PM
JAM3Z
Phenom
JAM3Z's Avatar
My car is still doing this! Any other ideas? I haven't tried cleaning the sensor, but I don't know why that would cause it.
Old 04-23-2010, 06:27 PM
JAM3Z
Phenom
JAM3Z's Avatar
Quick Reply: APP Sensor - P2122 & P2138 - CEL
