kinetex V+ install and whistle
Old 10-26-2007, 04:47 PM
gtstang03
gtstang03's Avatar
Default kinetex V+ install and whistle
Hello guys
i am know i pretty new here, but have done lots of searching and few mods to the z. I recently installed the kinetix v+ plenum. I love the power it made. It seems to idle fine, sometimes pops or rough, but it sorta did this prior. But at part acceleration i get a whistle.
Do i have a intake leak. I am throwing a code too that i can't get to go away, this could be from my Test Pipes, although i have non fowlers in.
People think i have a damn turbo cause the sound. LOL
I want to race it tommarrow night so should i spend the time ripping the intake off and reinstalling.
I added Thin amount of RTV last time, should i do this again.
Any info is great.
Thanks
David
Old 10-26-2007, 05:58 PM
ofl0926
ofl0926's Avatar
check to make sure everything sealed right.
Old 10-26-2007, 06:02 PM
srt4-no more
srt4-no more's Avatar
have a leak sumwherr... take it up the top of 2nd and the press the clutch in. if it dies on u its a pretty bad leak. jus run u hands all the way around the plenum and u should be able to feel the air... jus happened to me the other day when i installed my ssv.
Old 10-26-2007, 08:48 PM
Spray starting fluid around the edges while its running and see if you hear a difference. Next , why did you RTV it ?? Last mine has a slight whistle to it too , its probably normal.
Old 10-27-2007, 09:19 AM
gtstang03
gtstang03's Avatar
Spay starting fluid around the edges while its running and see if you hear a difference. Next , why did you RTV it ?? Last mine has a slight whistle to it too , its probably normal.
Hey guys, thanks for all the response to a newbie on the forum.
I went and bought some starting fluid and sprayed it around the edges and nothing, no engine sound change. I even held the rpms at 2500 too to see if it owuld do it.
I do have a whistle when shuting down from a tube coming out of the passenger side of the plenum. But seems normal. It just pops at idle a little bit, which i heard is normal.
I used rtv as i read it on a write up somewhere. it was a very thin bead.
The whistle is pretty loud but it is only at part throttle and between 1800-3000 rpm, full throttle does not do it.
Old 10-27-2007, 10:38 AM
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hydrazine's Avatar
That's normal.
Even the spacers make that whistle sound.
Old 10-27-2007, 05:29 PM
black06z
black06z's Avatar
Heard a lot of good things about this V+. Made a big difference with a reflash.
Old 10-27-2007, 05:54 PM
jcpeyton
jcpeyton's Avatar
I've had the V+ for 8K miles so far. 0 problems. There is a specific tightening pattern and torque specs for the plenum that need to be followed closely.
Also. periodic checking of torque specs in the designated order and adjusting accordingly may be a simple answer.
Kinetix was VERY helpful when I had questions during the installation process. Maybe call them??
Old 12-14-2010, 08:32 AM
slmdchvy05
slmdchvy05's Avatar
I didnt know there was any specific pattern to tighten the manifold down, but I do now... I have had mine for over a month and just used a t-handle allen wrench on mine to tighten it and have had no problems at all with it, I prob should get a tune but all I have done is the maifold and K&N intake other than that stock...
Old 12-14-2010, 01:05 PM
Even with the pics and all you still can't figure out you do not own a V+ plenum.
Old 12-14-2010, 01:43 PM
slmdchvy05
slmdchvy05's Avatar
I misread the title and pics don't always pop on my comp at work so there for I did not have any pics to look at at the time. I understand the difference between them now. My bad next time I'll try to use a comp that will show pics on every thread.
MAZ350
09-21-2017 07:21 AM
350ZZJoe
04-28-2016 02:11 PM
3fittytouringz
05-03-2010 09:33 AM
brick1
04-22-2006 07:56 AM
mchapman
Australia/New Zealand
04-13-2004 12:27 AM
Quick Reply: kinetex V+ install and whistle
