Why does the gas pump stopped even my car's tank isnt full?
Old 10-20-2007, 01:47 AM
hidehide
hidehide's Avatar
Default Why does the gas pump stopped even my car's tank isnt full?
It happened recently..
The previous 3 times, it stops at around 50-70% of the tank..
Does anyone know why??
Old 10-20-2007, 02:55 AM
xbreakerx
xbreakerx's Avatar
use the search button
Old 10-20-2007, 03:53 AM
Z04
Z04's Avatar
this happens the same way that n00bs can not use the serach button or check out the top 100 asked questions sticky at the top of the thread before posting.
plus the gas pump thing is 99% operator error
Old 10-20-2007, 04:19 AM
CervanteZ
CervanteZ's Avatar
Try Diesel instead.
J/K...
Try using a different pump. My car did that for the first few weeks, but only on certain pumps.
Old 10-20-2007, 07:50 AM
Eagle Z
Eagle Z's Avatar
Default simple
i think all you peeps need to shake your head...
a gas pump...is a freekin gas pump. they all have automatic shutoffs. this occurs when the level in the tank reaches the spout of the nozzle. sometimes....when you are pumping gas....certain pumps will pump alot faster than others...and gasoline will foam...heavily...and if the foam reaches the nozzle...the pump will of course...SHUTOFF...
so...and i have tried and tested this....when it happens again...and im sure it will...cuz it happens to me...just wait a minute or two...and you will find that the gas will go in without a fuss...
it could be the design of the tank...maybe the gas splashes around alot...making alot of excess foam...but it is possible to fill the tank...with any gas pump...they are not designed to fill only certain cars...
anyways...thats my take on it.
Old 10-20-2007, 04:46 PM
Vencer23
Vencer23's Avatar
stop bashing.
Anyway, happens to most of us. What I do is wait for it to auto kick-off, then take the pump handle nozzle half way out of the hole (to raise the angle) and continue to fill it up until it turns off again. Check out your current price and while seeing if the fuel is almost spurting back out of the tank, tap the pump a few times to hit your desired $ total. haha...gas pumping for idiots.
Old 10-20-2007, 08:30 PM
Lady Jax
Drive For Pole
Lady Jax's Avatar
You boys should be ashamed. You were noobs once, too. As to the problem of the pump shutting off early, check the Technical Service Bulletins and you will find that your model-year has a problem with an overly-sensitive valve in the gas tank and it needs to be replaced. In high temperature and high humidity it flaps closed before the tank is full and shuts off the pump. The TSB's are listed at multiple sites and at Nissan (where they want you to pay for the privilege of viewing). Check *********
Old 10-20-2007, 08:32 PM
Lady Jax
Drive For Pole
Lady Jax's Avatar
Damn, the 'nanny program' blocked the web address. Let's try spelling it out.....three fifty Z - tech dot com. I hope that works.
Old 10-20-2007, 09:09 PM
track1z
track1z's Avatar
Well Its never with the Z, Now with the Expedtion its cause at 75 bucks its a theft deterant at gas stations
Old 10-22-2007, 06:07 PM
hidehide
hidehide's Avatar
Lady Jax is correct.
Thats exactly what the dealer told me when I brought my car to install my new exhaust and to check.
They say I need $160 to fix that.. since my warranty just out..
but I didnt do it since I dont have time...
damn it....
Old 10-23-2007, 12:19 PM
md350
md350's Avatar
Pull the nozzle halfway out when filling.
Old 10-23-2007, 12:25 PM
VO...
Administrator
VO...'s Avatar
Fail.
It's a TSB.....
VO(knows common sense would hold true for the post above if we were talking about cars/pumps in general, but not the 350z)
Old 10-23-2007, 04:56 PM
paradigm
paradigm's Avatar
i love it when people post the "use the search!" bashing. if it bothers you so much just ignore the post and move on. why even allow new posts with that logic...just use google or call your local mechanic for every problem, right? forget open discussion. geez.
here is the answer for the OP:
TSB 05-048 Fuel Tank Difficult To Fill ...fuel tank shutter valve issue.
Old 10-23-2007, 05:06 PM
fithamoto
Sleeps in 350Z
fithamoto's Avatar
Stop using that Gas station.
Old 10-23-2007, 10:42 PM
hidehide
hidehide's Avatar
They just got too much time..
Recently I was reading lots of post on how to unlock iPhone.. while I see lots of people keep asking the same question..
I wanna ask them to search..
but when I plan to click on the reply button.. I think its waste of my time, then I go ahead to find more information instead..
Old 10-25-2007, 01:17 PM
aloh
aloh's Avatar
+1. My Z doesnt like this one Shell gas station i used to go to. It would cut off fuel before it was full. It works perfecly fine in any other gas station ive been to.
Old 10-25-2007, 07:50 PM
antennahead
antennahead's Avatar
also if you turn the handle at a 90 degree angle, up to 180 degrees, upside down, it seems to go in to a full tank without stopping. Not sure why this works, but for me, unless the pump is unusually fast, the 90 to 180 thing always allows for a full fillup at full speed.
John
Old 10-26-2007, 09:02 AM
VO...
Administrator
VO...'s Avatar
John
Intresting....
Old 10-26-2007, 09:24 AM
shushikiary
shushikiary's Avatar
John
+1 I do this, though it doesnt always work, but 90% of the time it does. If this doesnt work, then I pull it out half way and do as others have said.... just kinda figured it out by trial and error.. lol
Old 10-26-2007, 10:37 AM
XIceDragonX
XIceDragonX's Avatar
i usually just get mad and when i get in my car, throw a lit cigarette out into the puddle of gas i left on the ground because it spat back out of the car...
Quick Reply: Why does the gas pump stopped even my car's tank isnt full?
