PROJECT : BUILT VH45DE TT on a G coupe
Old 09-13-2007, 04:51 PM
supra crazy
supra crazy's Avatar
Wow looks pretty good I didn't know anyone mad pistons for the VH... Hopefully it comes along well the whole setup probably will cost less then a built vq. Also did you buy the 300zx adapter plate yet?
You probably already know this but nicoclub.com has a good amount of info on VH's. You might wanna check it out. I was planning on doing a VH swap in my S14
Old 09-13-2007, 05:14 PM
Jason333
hi
Jason333's Avatar
WOW this may be one of the coolest projects ive seen on here!! How hard are these motors to come by?
Old 09-13-2007, 06:25 PM
supra crazy
Pretty easy and usually under a grand.
Old 09-13-2007, 07:35 PM
Blazemaster
Blazemaster's Avatar
how will the v8 fit within the engine bay of the G? Does it require you to get stroker kit looking hood?
Old 09-13-2007, 07:43 PM
bverschage
bverschage's Avatar
very nice project, keep us updated!
Old 09-13-2007, 07:47 PM
rythex
rythex's Avatar
oooo, V8.... subscribing :P
Old 09-13-2007, 10:17 PM
BRS0903
BRS0903's Avatar
Damn! That is sick! I can't wait til this project is done!
Old 09-13-2007, 11:26 PM
tecni
tecni's Avatar
Originally Posted by Motormouth
interesting thoughts between the two engines.
what if any problems do you think you are going to encounter when trying to get the engine running? are you converting to a throttle cable?
are you keeping all the accessories?
Yes, I'll be converting to throttle cable but that's not difficult at all. I'm more worried about the oil pan not clearing the sway bar but I'll end up modifying one or the other. I've seen a few people running dry sump so that's an alternative.
Old 09-13-2007, 11:29 PM
tecni
tecni's Avatar
Originally Posted by Fluid1
What compression pistons man? Best of luck, I hope you don't hit many snags along the way. Any predicted completion date?
Compression is 9:1
Target completion time is end of year. I'm hoping for sooner but I believe 3 1/2 months might be enough.
Old 09-13-2007, 11:31 PM
tecni
tecni's Avatar
In your signature: classified 6-speed transmission
Which one is it?
I have an alternate 6MT tranny around but I'm sticking with the VG tranny for now.
I'd like to get a V160 getrag.
Old 09-13-2007, 11:37 PM
tecni
tecni's Avatar
Yeah, I have a few posts on nico and have researched a bit on there about the VH/VK.
Nobody really makes pistons for the VH, we had them made to order although I'm sure manufacturers will catch on since the VH/VK is becoming a pretty popular swap for different cars.
I know a guy here in Orlando putting a VH in an S13 and running a GT-r awd tranny. Should be nice...
Old 09-13-2007, 11:40 PM
tecni
tecni's Avatar
I'm fully stocked with these.
...they're not rare at all.
Only thing is that VH's are old and most have tons of miles and need nearly everything replaced.
Old 09-14-2007, 12:29 PM
GlenRoseFireFighter
GlenRoseFireFighter's Avatar
subscribing
Old 09-14-2007, 01:52 PM
Volk350Z
Volk350Z's Avatar
nice..
Old 09-14-2007, 05:19 PM
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
Originally Posted by failsafe306
You should put a link to this in the FI forum.
+1! It will get a lot more exposure in the FI section and deservingly so!
Tecni,
Just curious... The only other G35 I know of with a Q45 engine swap and twin turbos is Top Secret's car, and Smoky used a VK engine. Was that car your inspiration for your project?
I think it has been a couple years now since Smoky built that car and ran it on the autobahn at 200+ mph. I'm kinda surprised that we haven't seen a least a couple guys/shops here in the US try to do a similar build with a Q45 V8 since. I always thought that Top Secret car was absolutely badass. It showed it was possible to fit a V8 and I thought it would spawn other V8 equipped G's and Z's in both NA and FI form.
Good luck! I look forward to seeing your updates and final results!
Old 09-16-2007, 08:06 PM
tecni
tecni's Avatar
Tecni,
Well I was looking to do do something a little different so I began looking into the RB26 swap but found too many people had already done that, also, lack of parts availability kept me looking for other alternatives. I even considered picking up a 2JZ-GE but going that route would have been somewhat sac religious. Finally I laid eyes on TS's VK swap and realized it couldn't be that hard. Eventually I ended up at the salvage yard and picked up a high mileage VH for a very reasonable price.
Why VH over VK? I don't know... Oldschool rules?
Old 09-16-2007, 08:34 PM
Quamen
Quamen's Avatar
Funny you should mention the 2JZ engine...
I am going to be looking into the swap this winter. I have a 2JZ-GE engine (which is what I would most likely get due to the cost) that I will more then likely use this winter to try making an adapter plate so it fit the 350z 6-spd. All of this will be after I finish my Z33Art Supercharger kit.
So far I have contacted some companies that make flywheel/clutch combos for the Z/SC300/IS300/Supra non-turbo to get a Z clutch retrofitted to a 2JZ flywheel plus the thickness of the adapter plate.
Good luck on your VH swap!
Old 09-16-2007, 09:50 PM
  #38
tecni
tecni's Avatar
forget the VQ 6speed and just get a V160 or V161. It will bolt right up.
Hefty price tag though... $2,700 but will handle 1000+ hp
Old 09-17-2007, 05:26 AM
  #39
Quamen
Quamen's Avatar
Yeah that is why I'm gonna just try using the 6spd for the time being if I go this route this winter.
Old 09-17-2007, 09:05 AM
  #40
tecni
tecni's Avatar
Good luck with that. Let me know how it turns out.
Quick Reply: PROJECT : BUILT VH45DE TT on a G coupe
